Old 04-01-2003, 01:03 PM   #1
match71gmc4x4
front leaf spring bushings
Where is the best deal to get a complete set of front leaf spring busings for my 71 GMC 1/2 ton 4x4?
match71gmc4x4 is offline   Reply With Quote
Old 04-01-2003, 03:28 PM   #2
Yukon Jack
Yukon Jack's Avatar
You might want to look at the greasable bushing setup sold by www.offroaddesign.com I'm very happy with mine.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-02-2003, 12:29 AM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
I will have a set of urethane bushings that are coming out of a set of rancho springs. I don't know if they have the same dimensions, but they have only been on truck 2 weeks. I am returning the Rancho's to the pain in the a$$ salvage yard I got them from and installing a set of Tuff country springs that I got from Chris H. Bushings will be 50% of what they cost me if my mechanic is unable to return them.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 04-03-2003, 10:09 PM   #4
Big Bad Buddy
i use the greasable ones that were mentioned and have also had good luck with the poly urethane bushings i got from central 4wd or you can get them from 4wheel parts wholesalers at a reasonable price too. the ones that were mentioned from a set of rancho springs will only fit rancho i have found... have a good day.
78 chev pu 12" suspension lift, 3" body. 40" swampers. 85 body. yellow. 69 K5 blazer 6" suspension lift, 3" body. 38" swampers 84 suburban 6" lift 36" swampers... everyone needs a tow rig!!! 70 chev pu with big plans for bags and20's....
Big Bad Buddy is offline   Reply With Quote
