Old 06-14-2011, 04:42 PM   #1
Rumblefish
converting a 68' gmc 2500 8 lug front to a 1500 5 lug setup.
Is this just a question of springs, spindles and 5 lug rotors or is there somthing I'm missing? Any help would be welcomed! Its a super nice original truck,327, original paint, been in california its whole life so no rust pictures coming soon!
Rumblefish is offline   Reply With Quote
Old 06-16-2011, 08:44 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: converting a 68' gmc 2500 8 lug front to a 1500 5 lug setup.
Differences:
spindles
lower control arms
rotors
calipers
steering linkage
tie rod ends
Give us a little more info on what you have planned and what parts you have.
Total suspension rebuild?
Lowering?
Keith
Convert to disc brakes.
Old 06-21-2011, 09:05 PM   #3
Rumblefish
I just want to get this sucker down! Early classics has a custom spindle with a 2 1/2 '' drop that bolts right on and is designed just for this conversion.
Old 06-21-2011, 10:15 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Since you plan to lower it, do you also plan to go to aftermarket wheels? If so, you should look at the limited options available in 8 lug before you make your decision. Yes you can drop it with the ECE spindles, but then your wheel/tire selection is very limited.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-21-2011, 10:27 PM   #5
lolife99
lolife99's Avatar
The ECE "conversion" spindles for 3/4-ton trucks allow you to use 1/2-ton 5lug or 6-lug rotors without changing balljoints or tie rods.
You will also need to use 1/2-ton calipers, dust shields, and bearings.
Keith
