Old 06-14-2011, 08:33 PM   #1
lt704
prndl gear selecto question
Hi folks, I did some searches but still have a question. My gear pointer on the colum is too far left pass the park line, but the truck is in park. This follows true for the rest of the automatic gears on the pointer on my 68 truck with the exception of drive low 2, i cannot get the selector to that. Could someone explain how to correct this?, step by step. I appreciate it very much...Russ
1968 Chevrolet C-10 2 wheel drive
Lil' Red
In life always try to make a difference
lt704 is offline   Reply With Quote
Old 06-14-2011, 09:44 PM   #2
jondancer
Re: prndl gear selecto question
There are a few threads on this , I asked the same question awhile back.
I can't do the link from my phone but just search, it's out there
jondancer is offline   Reply With Quote
Old 06-14-2011, 09:56 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Truck in park, block wheels, open hood, locate lever coming out the side of the steering column with a rod attached that goes to the trans. At the top of that rod is a clamp that holds the rod in place, loosen the clamp with a 9/16 wrench. Climb inside and move the shift lever to line up with park, it should move easy and truck should stay in park. If it doesn't stay in park the clamp is not loose enough, return to park, loosen clamp and try again. If it does stay in park, line up indicator and then tighten the clamp on the rod. Clear as mud
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-14-2011, 10:20 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you are as talented as I am, you might want to grab a buddy......I just couldn't do it all, by myself, and be satisfied it was perfect. But, it ain't hard to do.
Member Nr. 2770
Old 06-15-2011, 04:48 PM   #5
lt704
thanks for the good information guys. ucmcchevy very good steps you have given me. I might have modify it a little. I have a Lokar kit on mine due to i could not use my regular transmision linkage due to the headers and custom exhaust. thanks for all your help. Russ
Lil' Red
Old 06-16-2011, 07:23 PM   #6
usmcchevy
usmcchevy's Avatar
That is what I have on my current truck. You will need to shorten the linkage. The ends are threaded on the top and bottom, hopefully you can screw them on more, if not you will need to cut the rod a bit shorter.
Build thread
LSx Swap FAQ index
