06-14-2011, 09:26 PM | #1 |
suburban mount help please
i know for the flat ones you can use the 67-newer rubber pads,but took out everything and its been a couple years not sure what goes under the front core support,and are the front four the same as the truck, is there a diagram outthere, or someone who sells a package with all the mounts and hardware thanks
1966 suburban slammed fuel injected 6.2L My build |
06-15-2011, 12:55 AM | #2 |
60-66 Nut
Re: suburban mount help please
On the Suburban and Panel frames, the radiator support mount on the frame is of a bonded rubber design. So the radiator support bolts directly to that. The next mount back, at the front of the 'cab' is the same as a pickup. The next one back at the 'B' pillar, I don't know for sure what should be used there. Maybe someone else knows for sure.
06-15-2011, 09:37 AM | #3 |
"b" pillar insulator is the same as the rest of the other 12 rear insulators used-16 in total
ron |
07-01-2011, 09:53 AM | #4 |
send email, just did mine and also have parts!
07-02-2011, 06:08 AM | #5 |
the rear mounts have different size holes, check first! i used 67 mounts but had to adapt them to smaller holes on some
