PRNDL issues
I have questions that some may think are trivial. So I apologize in advance.
The PRNDL in my 69 C20 seems loose, out of adjustment and lacks "indents". So I need advice from the experts on addressing these issues concerning. 1) Where is the indents, column, tranny? 2) How can I made the shift lever feel less like a wet noodle? A side note, I think the column has been switched out by a prior owner. How can I identify it, pictures, numbers and/or shape. Thanks in advance. |
Re: PRNDL issues
I believe the detents are in the transmission.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: PRNDL issues
As for ID on the column, show us a pic and someone here can give you a good guess.
Last time I had a shifter feel mushy, it was a combination of the threaded pin that holds it at the column and some loose fasteners on the column, under the hood. . Last edited by ETsC10; 06-14-2011 at 11:55 PM. Reason: goobed |
Re: PRNDL issues
Maybe this will help. Here are photos of the PRNDL and Steering Wheel.
Can anyone tell me what this column and PRNDL ID is? Last edited by gmebey; 06-19-2011 at 02:21 PM. Reason: Photo posting issues |
Redefining LowBudget
Re: PRNDL issues
looks like its out of our truck vintage with the wrong indiccator on it..try looking at where the linkage meets the column mine was like that I used the plastic cap that comes in the end of an air fitting to shim mine but you can buy a new one for cheap..
have someone move/wiggle the shifter while you look under the hood
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Has more rust than truck...
Re: PRNDL issues
X2, That indicator is for I believe a aftermarket tilt column. Get the correct indicator then do the adjustment I tried to explain here.
http://67-72chevytrucks.com/vboard/s...d.php?t=469685 Correct indicator. http://www.classicparts.com/1971-72-...ctinfo/91-365/ http://www.classicparts.com/1971-72-...ctinfo/91-355/ Last edited by usmcchevy; 06-19-2011 at 03:57 PM. |
Re: PRNDL issues
usmcchevy,
Your links are for 71-72.....is this the same for 69? Thanks, Gerlad |
its all about the +6 inches
Re: PRNDL issues
looks like a 71/72 column with the older style PRNDL (perndle) and the later pointer.
The detents are in the column. These columns were a crappy design and are known for doing this. Soon the shifter will start to bind, and the lever will get stuck in either the forward, or the pulled back position. Personally, I would swap it out for a tilt unit. Either truck tilt (if you have the funds) or you can convert a van tilt, which sell for next to nothing. |
