Old 06-14-2011, 11:16 PM   #1
75sierraclassic
75sierraclassic's Avatar
Inner Tie Rod HELP
I've got a 2003 Silverado standard cab short bed 2wd 4.8L with rack and pinion steering. I'm trying to replace the inner tie rod and got it all torn apart tonight. On the rack, there is no flat spot to put a wrench to hold the rack while you unscrew the tie rod. See pics. My service manual says there should be a flat spot to put a wrench. Anyone know whats up and/or how to remove it without damaging the rack?
75sierraclassic is offline   Reply With Quote
Old 06-15-2011, 07:17 AM   #2
truckdude239
truckdude239's Avatar
Re: Inner Tie Rod HELP
you need an innner tire rod removal tool
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-15-2011, 08:21 AM   #3
75sierraclassic
I have the tool with a barrel that slides over the tie rod and a spanner on the end that engages the tie rod end, but no way to keep from transfering all the torque through the rack. Am I missing something? Do I not need to worry about torquing on the rack, just put the tool on and crank away?
Old 06-16-2011, 02:43 PM   #4
75sierraclassic
Got some input from a past GM Tech my dad knows. He said to not worry about holding on the rack and just crank the tie rod end off. Gonna try it tonight and see what happens.
Old 06-17-2011, 04:15 PM   #5
truckdude239
yeah you dont Have to hold the rack just take it off
David fuller
2000 Tahoe 5.3l 378
Old 06-20-2011, 01:35 PM   #6
75sierraclassic
Worked pretty good. Just screwed the old one off and screwed the new one back in. Took some force to get it off, but I knew it would. When I got it back together there was some clunking coming from the rack but it seems to have straightened itself out after a few days. I guess by torquing on the rack I might have tweaked something but it seems to have settled back into place.
I didn't realize that there were instructions with the new tie rod end. It said that the flat spot on the rack is only on the drivers side. I only wanted to replace the passenger side (yeah I know, I'm cheap, I should have done both) so i didn't' take the drivers side apart to check. It would make since though.
Old 01-11-2015, 10:06 AM   #7
saulgoode
saulgoode's Avatar
Strong work! Glad you were able to get your rods replaced!
I am having a had time getting the inners broke free.
I see in your pics the pink collar is pushed back. Best I can tell these are collars that go over the big end of the rod that screws onto the rack. Mine is cracked. Any safety performance concern to go without this part? Having a hard time locating at my parts house.
saulgoode is offline   Reply With Quote
