Old 06-15-2011, 12:44 AM   #1
ibbig
Question 454 crewcab ??????
hi im new but does anyone have any pics of where the heatriser mounts to on a 1980 chevy crewcab i cant smog it with what i have on it thy say its the wrong one
ibbig is offline   Reply With Quote
Old 06-15-2011, 11:24 AM   #2
Low87
been here longer than Liz
Low87's Avatar
Re: 454 crewcab ??????
Are you talking about the collapsable tube that goes between the heat collector on the exhaust manifold and the fresh air intake?
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 06-15-2011, 05:30 PM   #3
ibbig
no its the valve that gos between the exuast manifold and the exuast pipe out mine needs to be vacume but it has a mecanical one on it so it wont pass visual and all the ones i looked at online show what i have.
1980 chevy 1 ton crewcab
Old 06-15-2011, 05:46 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
I didn't take photos of mine before I removed it and blew the valve out of it so it was just open pipe... Must suck to live in a place with emissions.
Well I did find one photo. It bolted on to the manifold bolts and had a rod going down to the butterfly valve. The vacuum lines went to a port on top of the water neck.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 06-15-2011, 06:16 PM   #5
ibbig
Smile Re: 454 crewcab ??????
cool thanks that is what i was lookin for now i got to find the whole thing
cheap hopefully
Old 06-15-2011, 09:06 PM   #6
RandyP
RandyP's Avatar
I'll dig thru my box of left over junk I removed and see if I still got mine or not.
Old 06-15-2011, 09:12 PM   #7
ibbig
sounds good just let me know thanks
Old 06-16-2011, 09:34 AM   #8
blakeduren
my 83 454 had one between the exhaust manifold and the pipe like you said before. The valve was mounted right there then had the metal vacuum tube run up behind the block to get vacuum from one of those senders mounted in the coolant flow in the front of the intake manifold.
blakeduren is offline   Reply With Quote
Old 06-16-2011, 07:54 PM   #9
ibbig
ya i just not sure witch one i need
Old 06-16-2011, 11:14 PM   #10
blakeduren
the one i have has "158WN" stamped on the cast part that the exhaust goes through. I the vacuum pot doesn't have a number on it.
Hope this helps...?
Do you have the cast iron part? Do you have the vac acuator part?
Old 06-17-2011, 07:42 AM   #11
RandyP
RandyP's Avatar
I guess my guys threw away the box I had with all the emission parts and vacuum lines and junk. After a while you do get tired of tripping over stuff, so I don't blame them and I really had no use for it.
Old 06-17-2011, 11:41 AM   #12
ibbig
no prob i think i found one on ebay for $113 im still tryin to research it more
Old 06-21-2011, 09:10 PM   #13
ibbig
thanks guys for all the info i found what i needed for 45 bucks now to redo the vacume lines
80 crewcab 454
