Old 06-15-2011, 05:54 AM   #1
anson0487
One of these days.......
anson0487's Avatar
TBI questions
I recently converted my 84 to TBI, using a 90 suburban for a parts doner. i bought a new 87 model fuel tank and modified the 90 sub fuel sending unit and pump to fit... now my questions are, what year models sending units will fit correctly, new pumps are cheep but id like to find used sending units...any ideas on fuel lines? parts stores here dont have the fittings needed to make these type lines, has anyone used the steel braided lines from 90 and up trucks to make lines all the way from tank to TBI? i want to install a duel tank set up later on, but i cant find any info on how that system works, does anyone have a wiring diagram for duel tanks? it seems like i could run two fuel pumps and the switch on the dash just shut off one pump and turn on the other but there would have to be a check valve in the line to keep from pumping fuel into the other tank?
anson0487 is offline   Reply With Quote
Old 06-15-2011, 07:05 AM   #2
b454rat
Re: TBI questions
Stuff off an 87 to 91 should work. Came factory TBI with the dual tanks.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 06-15-2011, 02:24 PM   #3
anson0487
anson0487's Avatar
Re: TBI questions
Thanks b454rat, you said 87-91 parts will work, does that include the 88-91 trucks? or just the square body suburbans? i like your profile pic, thats about what im building, except not 4x4... ill post a pic
Old 06-15-2011, 03:05 PM   #4
anson0487
anson0487's Avatar
Re: TBI questions
Old 06-15-2011, 04:00 PM   #5
anson0487
anson0487's Avatar
Re: TBI questions
Old 06-15-2011, 06:55 PM   #6
ghettoluxury
ghettoluxury's Avatar
Re: TBI questions
Just the square body style trucks. The crew cab was still offered until 91 as a R30 and V30.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 06-15-2011, 10:17 PM   #7
onpoint
Re: TBI questions
i have a 88 r30 with a 454 tbi engine with dual tanks. it has dual fuel pumps and a fuel selector on the frame. here is a electrical diagram if the system.
onpoint is offline   Reply With Quote
