Old 06-15-2011, 02:02 PM   #1
Boog
laying low
Boog's Avatar
straight steering column ?s
I dug out some columns I picked up some years ago and not sure what I have. I have pics of two auto columns. The green one I believe to be from a 71. Notice the round black hazard switch and straight harness connector. The bearings are bad and shifter is siezed.
The blue one looks to be an earlier model. Notice the slim red hazard switch and round harness connector.
Is the green one from a van maybe? Although it doesn't have the extra length steering shaft. It has the 17" wheel and 9" shift handle.
Both of these have the 3 speed auto detent plate.
I am heading to buy some new parts to fix one of these for my 69.
Isn't there supposed to be a big spring in the lower end to keep the shaft pulled down in there snug? Thanks for your help.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-15-2011, 07:14 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: straight steering column ?s
There is a tension spring and a large washer that goes on the end of the shaft and seats against the coupler.
LockDoc
Leon
Old 06-15-2011, 11:13 PM   #3
ls1nova71
ls1nova71's Avatar
They're both truck columns, the green one has probably just had the turn signal switch replaced.
ls1nova71 is offline   Reply With Quote
