Moderator
![]() Join Date: Oct 2008
1985 tilt column in 1976 cab?
Has anyone tried this?
I have a 1985 tilt column in a rusted out donor cab. Will the 1985 column bolt into a 1976 cab? Will I need to move or swap the firewall plate or U bracket? I'm not asking about the wiring differences. They can be sorted... I have GM Helm Inc. schematics for 1973-1986 gm trucks. The donor has cruise and pulse wipers. I have the whole cab so I may just grab the entire cab harness and re-pin the engine compartment firewall connectors where needed. |
Moderator
Re: 1985 tilt column in 1976 cab?
HMM Nobody?
should be a strait swap minus wiring
Edited by staff |
Moderator
78K & 79C Jimmys
that is a few projects down the line for me
but 88 or 89 to 78 what i've read the wires are the problem i believe it was different 77 and before and 78 and after hope you figure it out..........and post ![]()
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Hi hatzie,
I believe GM changed from a splined shaft to a double-D shaft at the lower end of the steering column sometime around 79. Shouldn't be a problem though ... just use the matching intermediate shaft from the 85. |
My 78 has an 85 tilt column, but my uncle had it all installed when he owned the truck so I don't know details of the installation. The intermittent wipers work properly though, so I know for a fact that it can be done.
Jay 1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser. |
Moderator
I am planning on a Jeep XJ shaft to replace the rag joint at the same time but that's an important gotcha.
I'll post the wiring when I get it sorted. |
