wiring harness 66 truck
How do you decide which wiring harness to buy? is one brand better than the other. I have a 66 suburban and need all new wiring.
![]() Join Date: Nov 2010
Re: wiring harness 66 truck
I just bought a painless wiring harness through jegs just last week. All the wires are color coded like factory and seems to be pretty simple to install (this weekends project) but thats my 2 cents
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
are you going original or custom, meaning ac, radio, power other stuff, seats etc?
Either way, dont spend money on the cheaper harnesses, go with AAW ( American Auto Wire. MGBMike has them very reasonable, he is on the board here. Ive done the cheap ones and ended up doing the AAW Classic Highway series.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Oct 2009
if not a stock restoration - I personally like the ones that have the circuit name printed on the correctly color coded wires (i.e. "ignition" or "water temp sender" or whatever) - so instead of having to squint at a wiring diagram, your wire bundle is its own wiring diagram. But might look a little hokey - depends if you're a form over function sorta guy or the reverse. At a minimum, I'd make certain it's gm circuit color coded - and most of them are. Having said all that - I concur with Clyde, have heard nothing but good stuff about AAW. For that matter, have never heard anything bad about Painless either...
My 66 was totally gutted of wiring. I went with the 9+3 Rebel Wire package. It worked for my needs very well since I was not looking for an original rebuild. And excellent customer service.
http://rebelwire.com/rebel-wire-prod...at=Wire%20Kits |
Here is a previous thread on this very subject: The Wiring Harness Thread
It's Better With Nitro
If you're looking for a product review...I've wired several trucks and hot rods using Ron Francis kits and they are by far the best that I've used, along with excellent service.
#8 | |
If my truck is still with me in 10 years, I will be surprised. Quality installation is nearly half the battle.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
