06-15-2011, 09:42 PM | #1 |
lowering help
Hey fellas in the past couple months I have installed cpp's 3/5 loading spring kit and I have been noticing that the back sits alot lower than the front almost like one of those mexican mobiles. My question is am im doing something wrong I made sure that the front springs were seated properly. Also do many people have problems with this kit?
Thanks Bryce Posted via Mobile Device |
06-15-2011, 09:49 PM | #2 |
Re: lowering help
that sux.....i have the same kit but have only done the frt....my driver side is tucking the front , but pass seems about an inch higher....did you get the shocks and tracking bar too?
06-15-2011, 10:55 PM | #3 |
Re: lowering help
No I didn't get the shocks or tracking bar I didnt think that it would make it sit like that though
06-16-2011, 11:30 AM | #4 |
Re: lowering help
Anyone else?
06-16-2011, 12:02 PM | #5 |
67-72 parts collector,…
Re: lowering help
A friend of mine bought the same parts.
Front sat higher than the rear also. He's adding drop spindles to bring the front down some more. You really need to add the adjustable track bar (to re-center the rearend in the truck),... and shorter drop shocks. Your stock shocks will be junk in no time.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-16-2011 at 12:04 PM. |
06-16-2011, 12:26 PM | #6 |
Re: lowering help
i've seen the same complaint at least 4-5 times with that same combination
foolish not to use drop shocks and adjustable panhard bar to properly do the job
06-16-2011, 01:25 PM | #7 | |
Re: lowering help
I bought CPP's 3-4" Lowering Kit with that included Springs, and Short Shocks. I already had 2.5" Drop Spindles in the Front, so after installation, I had a 5.5" Drop in Front. The Back STILL wasnt low enough, so I put on 2" Drop Blocks for a Total of 6" in Back. Never had a problem with one side being Lower/Higher than the other. That Drop was Documented at my Website below: http://home.pon.net/wwotr/towing.htm
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
06-16-2011, 04:19 PM | #8 |
Re: lowering help
Thanks fellas ill probably just buy some drop spindles and replace the front springs because im satisfied with the rear and buy the super track bar also
06-16-2011, 09:10 PM | #9 |
Re: lowering help
Yes, go with the trackbar, you need it. Your truck will drive a lot better too.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
06-16-2011, 09:53 PM | #10 |
Re: lowering help
I have 3/5 and adjustable pan-hard. Mine still looks a little lower in back. I also have had 3/3 on, was a little too high in back. I think the correct combo is 3/4.
Also, I have rumble at take off with 5 that I did not have with 3, I am certain it is u-joint angle. Again, I think 4 will cure this.... |
06-25-2011, 11:08 PM | #11 |
Re: lowering help
update: my frt IS noticeably higher than rear even with the drop shocks and new brackets..think im gonna cut a coil off the frt springs to level her out. wasnt r3ally going for the "lauching" look. =/
06-25-2011, 11:12 PM | #12 |
Re: lowering help
Guys I have lowered over 25 trucks and if your rearend stays centered can someone explain why you would need a adjustable track bar?????
06-25-2011, 11:13 PM | #13 | |
Re: lowering help
They will be too short.
06-25-2011, 11:15 PM | #14 |
Re: lowering help
Normally the rearend shifts to the passenger side.
06-27-2011, 03:56 PM | #15 |
Re: lowering help
06-27-2011, 06:44 PM | #16 |
Re: lowering help
Same thing with my kit that has dro shocks and adjustble pan bar my front is almost 3 in higher ordered drop spindles last week.
06-27-2011, 08:15 PM | #17 |
Re: lowering help
heres a couple of how my 3 5 cpp drop springs with their shocks look...the frt def has to come down some more!!
I am happy with the rear, although the ride is a bit bouncy now, but she is super tight. |
06-27-2011, 11:09 PM | #18 | |
Re: lowering help
There's something about the color paint and that Front grill thats says ...CLEAN!
06-27-2011, 11:13 PM | #19 |
Re: lowering help
Mine with a CPP 3-4" Drop and 2 1/2" Drop Spindles, and 2" Lowering Blocks in the rear, for a total 5.5/6" Drop.
