06-16-2011, 07:29 AM | #1 |
Resident of Here
Sudden death wobble?
So last night I was in a hurry home after spilling dad's 64oz soda on my front floor, so I turn onto our street and boom, deaht wobble really bad, I hit the brakes to stop because it felt like a loose wheel. I pulled in and torqued all the lugs to 107, I couldn't remember if it was 105 or 110. It's been fine since, I drove it 4 miles and tried to make it happen again. Nothing. Any explanation? I tried to shake all the steering linkage and it was all tight. Thanks, Bradley
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
06-16-2011, 09:25 AM | #2 |
Re: Sudden death wobble?
Did all the lugs (or most) on one wheel feel loose? Ball joints or tie rod ends can do that. You need to lift the front wheels,check horizontal play (3 & 9 o'clock) for tie rods and vertical play (6 & noon) for ball joints. Ball joints actually feel more like hopping and tie rods feel more like a shimmy.
06-16-2011, 09:49 AM | #3 |
Do you have a Dana60 frontend?
What size tires?
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
06-16-2011, 12:05 PM | #4 |
What?
Steering stabilizer installed and good?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
06-16-2011, 02:07 PM | #5 | |
Resident of Here
The 88 burb in my sig. 30x9.5R15 It has one, I think it's the stock 1988 one, don't know if it's good or not. How do I check?
06-16-2011, 02:28 PM | #6 |
Active Member
If it happens again, make sure you check your brake rotors for warpage as one of the things you check. I had a wobble problem for a long time with my 96 Dually, and finally traced it to that (after replacing everything else). Didn't do it all the time, more under braking (obviously), but it would set up a wobble reminiscent of a tank-slapper on a motorcycle.
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
06-16-2011, 03:41 PM | #7 |
What?
I would go to the local off road truck parts supply store and get a new one, since they are cheep enough and will help with shimmy and tire wear.
06-16-2011, 06:03 PM | #8 |
God is good!
As has been mentioned, check for play in the ball joints. They're not so bad to replace, check my build thread for a documented step by step. If all your bearings are good, you can get all 4 Moog ball joints from rockauto.com for around $100 and do the labor yourself!
As far as the steering stabilizer, it will not cause a shimmy. It is only there to keep the vehicle from wandering down the road. It won't cause a wobble.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
06-16-2011, 08:08 PM | #9 |
Resident of Here
Elephant, you dont have a 10 bolt lol, thanks though.
Thanks guys
06-17-2011, 08:45 AM | #10 |
If you didn't have vertical play your ball joints are ok. I'd suspect the tie rod ends more anyway. That's where you get the side to side play. Is your steering loose at all? Play in steering wheel? Check at 3 and 9 jacked up and also have someone work the steering wheel while you inspect underneath with tires on the ground. If a bad stabilizer is letting it wobble it's due to worn steering. Stabilizers are an add-on enhancement to the design,not a critical part.
06-17-2011, 09:51 AM | #11 |
Resident of Here
I have less play than the 83 burb. It's fairly tight. I dont have to keep moving the wheels side to side to stay straight.
06-17-2011, 04:02 PM | #12 | |
Living In The Past
06-18-2011, 06:50 AM | #13 | |
Also check into the steering box itself. Is it tight to the frame? Have someone move the steering wheel while you watch the box (and it's connectionto the frame). These trucks were notorious for cracking the frame at the mounting point.
Does this thing have any lift? tire size? etc.... As far as the original stabilizer....just replace it. There is no need for testing, it's over 20 years old.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. Last edited by LONGHAIR; 06-18-2011 at 06:50 AM. |
06-18-2011, 07:51 AM | #14 |
I'm thinking a warped rotor or something in the wheel/tires now.
06-18-2011, 10:01 AM | #15 | |
A warped rotor shouldn't give you a wobble, but a pulsing in the brake pedal. It can also be hard on caliper mounting brackets/bolts.
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-18-2011, 11:40 AM | #16 |
Living In The Past
As Mentioned before. Warped rotors WILL give it the death wobble.and do it randomly. I have first hand experiance with it in my 76 for years before I finally decided to fix it.
06-18-2011, 11:41 AM | #17 |
Resident of Here
It wouldn't be my rotors, my brakes are smooth and only 3500 miles old. I'll check my steering more in depth when I get back from FL. Thanks, guys
LONGHAIR, it's the 88 in my sig.
06-18-2011, 05:12 PM | #18 | |
That doesn't tell me a thing about how/if it has been modified....
06-18-2011, 05:16 PM | #19 |
Resident of Here
The truck is entirely stock except for 1" larger than stock tires. 30x9.5R15.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck Last edited by thirdstreettito; 06-18-2011 at 05:17 PM. |
