06-16-2011, 10:55 AM | #1 |
drop spindles
Has anyone used airbagit.com's spindles? I have a C20 and I am looking for spindles.
Thanks Posted via Mobile Device |
06-16-2011, 12:13 PM | #2 |
67-72 parts collector,…
Re: drop spindles
My advise would be to stay away from airbagit.com.
Search AIM, Chassis Tech, or the newest name, airbagit.com for all the poor customer service and product reviews. www.PerformanceOnLine.com sells C20 drop spindles.
06-17-2011, 02:30 AM | #3 |
Re: drop spindles
Thank you. I ordered them today from POL.
06-29-2011, 07:45 PM | #4 |
Re: drop spindles
I had bad luck with them to, I just read a lot about spindles and from what I have been told djm is the way to go, Some of the others space the rims outward. But I do not know this for sure. Ya know everything you read on the internet is true!
07-02-2011, 02:59 PM | #5 |
Re: drop spindles
Thanks. The only place i could find c20 spindles besides airbagit was POL. I ordered them from POL along with springs etc. Hopefully ill get the kit on in a week or two.
07-03-2011, 02:04 PM | #6 |
Re: drop spindles
Early Classics in Fresno,Ca sells c20 drop spindles and a direct c20 5 lug conversion
Pulatoy |
07-03-2011, 11:59 PM | #7 |
Re: drop spindles
I bought the POL C20 drop-spindle and 8-lug disk brake conversion about a year ago. Great product for sure. They DID move the wheel out about 3/4 of an inch though. But stock wheels still clear the fender lip.
On another note... I did buy some stuff from airbagit.com, and so far so good, other than the instructions are lacking what this novice needs.
Eric '68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=403690 |
07-04-2011, 09:45 PM | #8 |
Re: drop spindles
Thanks Mulk. I have the spindles now just waiting to install them. Got 5" springs for the rear and the new track bar. When you put those new wheels on did you have any clearance issues with the front being moved out?
07-05-2011, 01:56 AM | #9 |
Re: drop spindles
I had a set of centerline 16in when I did the swap, and they rubbed. I had to go to stock to clear. Although I was also running a 3in lowering spring.
I just had to find wheels with a crazy off-set to clear with bags. There are tons of wheel options out there if you shop around. The Fuel 20in wheels I'm running now have room to spare. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
07-30-2011, 10:56 PM | #10 |
Re: drop spindles
if you convert to the 3" drop spindles can you retain the drum brakes, or do you have to upgrade to discs?
07-30-2011, 10:59 PM | #11 |
Re: drop spindles
You have to upgrade to disc brakes.
