06-16-2011, 12:23 PM | #1 |
Blackdawg
help motor mount
i took pictures but doing this thread on my break at work.i have a motor mounts that were bolted to engine i bought privatley.they are u shaped with a hole on either side that the bolt goes through.the truck i bought had a 350 in it a one time.there is a lower bracket bolted to the frame there is a hole on the top.would there be a lower mount with rubber mount to this.is there something missing here i will upload pictures later.trying to describe the best i can.thanks
06-16-2011, 12:26 PM | #2 |
Who Me?
Re: help motor mount
Whats your question?
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
06-16-2011, 01:22 PM | #3 |
Senior Enthusiast
You might want to take a look at this thread and see if it answers your question:
http://67-72chevytrucks.com/vboard/s...ht=motor+mount The O'Reilly link isn't working correctly, so when you get there just type in 2282 and on the next page the item in the middle will be the motor mount that bolts to the engine. |
06-16-2011, 01:24 PM | #4 |
~Rest In Peace~
wrong mounts
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-16-2011, 05:13 PM | #5 |
Blackdawg
yes that doesn't look right.i will post the pictures later.
06-16-2011, 05:21 PM | #6 |
Blackdawg
here is a picture of the mount attached to the block picture 1 .the second picture is close what i have in the truck.there is one hole on the top of the mount.not the two holes as seen here.whats missing ?
06-16-2011, 06:28 PM | #7 |
you can change to the earlier mount on the eng and it will bolt to the existing perch or get a later perch and install that and it will bolt up to that mount on the eng. there may be a difference in height though
ron |
06-16-2011, 07:42 PM | #8 |
You need the mounts for the original small block perches 7-509BL $90 bucks for a good set from CPP, or for bout $40 bucks more you could switch to the CPP perches, here is a pic, excellent quality and use the mounts you have.
06-17-2011, 12:29 AM | #9 |
60-66 Nut
The motor mount bracket on your engine is for the '73 and up motor mounts. Just remove that from your engine, and bolt on a set of motor mounts for a '63-'66 truck with a V8. They should be the number 2282 that Mark posted. You will also need a couple 7/16"-14 bolts about 1-1/4" long as well as a couple 7/16" flat washers. I'm not sure how easy those bolts and washers will be to find up in BC though
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-17-2011 at 12:31 AM. |
06-17-2011, 12:50 AM | #10 |
there is more sae thread avail for sale than metric here; no problem
ron |
