06-16-2011, 12:28 PM | #1 |
4x4 Radiator Metal Hose?
Just bought a original 4x4 radiator metal hose from a member, and have a question. What's a good anticorrosive or paint spray to use on these hoses? It had minor surface rust, and I cleaned it inside out with sandpaper on the outside, and rust remover gel on the inside. It cleaned out pretty well. All I need now, is to spray a protective anticorrosive to prevent it from re-rusting in the future. Where can I get it from also? Thanks!
1972 Chevrolet Blazer 4x4 (Almost done stay tuned) 1970 Chevrolet Pickup Longhorn CST/20 (SOLD) |
06-16-2011, 01:02 PM | #2 |
What?
Re: 4x4 Radiator Metal Hose?
I have mine all ready to go as well, and have been wondering the same thing about the inside of the pipe.
Was thinking maybe POR-15?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
06-17-2011, 06:33 AM | #3 |
I always wanted to know what the pupose of these hoses were?
06-17-2011, 01:14 PM | #4 |
I cleaned mine about 10 years ago and simply sprayed it with #1613 Krylon semi-gloss. Other than some wrench nicks it still looks great.
The best thing about #1613 is you can't tell what the factory sprayed and what you sprayed and a can of touch-up paint is only as far away as Wal*Mart and about $3 in change.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
06-20-2011, 05:47 PM | #6 |
powder coat X2. it will protect the inside just as well as the outside.
1969 Chevy K20 Longbed |
06-20-2011, 06:37 PM | #7 |
From what I understand they put the metal hose in there because of the motor sitting farther back in the truck causing the distance to the radiator to be greater. There was a chance of the radiator hose pushing down into the fan blade
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
06-20-2011, 09:46 PM | #8 |
No help on the coatings, but is that a GMC specific part? That's the only place I've ever seen them.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
06-20-2011, 11:12 PM | #9 |
its all about the +6 inches
chevy trucks had them too
06-20-2011, 11:37 PM | #10 |
What?
I think they were 20 series specific as well.
06-21-2011, 03:48 PM | #11 |
Just an idea . . .
Maybe with the correct mix of glycol / water, there is not enough oxygen in the system for much rust to occur? If you think about it, these have been in our trucks going on 40 years and still not rusted out. You have to have oxygen for rust. Maybe some chemist can correct me here, because this is just my theory. Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
06-21-2011, 11:33 PM | #12 |
I make Models
they are K series specific.....
06-21-2011, 11:56 PM | #13 |
What?
