Old 06-16-2011, 12:53 PM   #1
wiredmelvin
lowering 1962 3/4
Is it possible to get a lowering kit for 62' 3/4 ton and where
wiredmelvin is offline   Reply With Quote
Old 06-16-2011, 12:56 PM   #2
jimmydean
jimmydean's Avatar
Re: lowering 1962 3/4
There isn't a lot of options for a 3/4 ton without a lot of swapping. It's even harder for the older fronts.
You can swap the front for an updated setup from a '73 C20 and there are much more options. I didn't find a whole lot for my '66 when I was first looking, but I didn't look at all possible options, either.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-16-2011, 02:15 PM   #3
kieth
kieth's Avatar
CPP has some 3/4 ton 6 lug drop spindles, check there, the rear is easier it should be on leaf spring, just put the springs on the bottom of the axle instead of the top.
maybe it was performance online, someone has 3/4 ton 6 lug that would fit a 88 burb front end which was my donor vehicle..
kieth is offline   Reply With Quote
Old 06-16-2011, 02:21 PM   #4
jimmydean
jimmydean's Avatar
I'm not seeing C20 drop spindles on their site. I had 6 lug C10 spindles on my '69, but couldn't find C20 spindles for the pre-73 trucks anywhere.
I did find some here just now:
http://www.performanceonline.com/196...dle-Set-16683/
But it doesn't say what rotor, just C10 heavy duty, so no telling what spindles it has and what will work. Since it's listed for the 60-62, I am guessing it uses the stock ball joints and tie rods.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-16-2011, 06:24 PM   #5
Surfdaddy
Surfdaddy's Avatar
Since your front end is torsion bars couldn't you just loosen them like the 1/2 ton guys do. Then just put in drop coils from CCP or someone. If you lowering it I'm guesing your not going to carry any heavy stuff.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
