06-16-2011, 04:29 PM | #1 |
327 PCV Grommet
Hey guys.
I need some help locating a PCV grommet for a 327. The 327 is a transplant from a '66. The grommet is located in the block back by the distributor and oil pressure switch. Any idea? Thanks. Q
'64 K20 327 |
06-16-2011, 04:36 PM | #2 |
Who Me?
Re: 327 PCV Grommet
Are you looking for an open vacuum port?
Nevermind. I miss read.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) Last edited by 61_FL_Apache; 06-16-2011 at 04:36 PM. |
06-16-2011, 04:46 PM | #3 |
Re: 327 PCV Grommet
I have a setup like this... looking for the grommet shown here:
http://www.parts123.com/parts123/yb....~Z5Z5Z5~Z5Z5Z5 I searched the PN shown and found this on eBay. http://cgi.ebay.com/ebaymotors/1963-...#ht_1324wt_939 I wonder if that would work. Q
'64 K20 327 |
06-16-2011, 05:06 PM | #4 |
Re: 327 PCV Grommet
That port is where the road draft tube is connected... pcv is usually located in the valve cover.
If your valve covers have a port use that and plug the road draft port on the block with an appropriate sized freeze plug. The road draft tube vents crankcase pressure straight into the air. |
06-16-2011, 05:58 PM | #5 |
Senior Enthusiast
Re: 327 PCV Grommet
The following thread shows installations with both a grommet and post #13 shows the early adapter nipple that bolted in the block hole with the same bolt that originally fastened the road draft tube:
http://www.jalopyjournal.com/forum/s...d.php?t=151629 |
06-16-2011, 07:50 PM | #6 | |
Re: 327 PCV Grommet
Awesome link. Thanks very much! Here is the setup I have, along with a vented cap on the oil fill tube... I'm sure I can come up with the right combination of parts to get it done. Thanks again. Q
'64 K20 327 |
06-17-2011, 04:04 PM | #7 |
Re: 327 PCV Grommet
and try a car catalog from Classic Industries that covers 66 (not camaro, too early)
292 + TKO500 |
