06-16-2011, 07:48 PM | #1 |
I6 250 Power Steering Pump Alignment
I am in the middle of a power steering conversion on a 68 with a 250. I have used Shiftys How To in the FAQ section and numerous other posts to get the the point I am at now.
All that I have left is to properly align the power steering pulley. My Issue: The pump pulley is off around 1/4 inch from the other pulleys causing the belt to want to align directly in the center of the double pulley I have. I have shimmed with washers without much luck due to the limits of the early 250 mounting brackets. I believe pulley offsets are going to be my fix but not sure. Can anyone advise an idea to align the pump with the current setup I have:
Would this be possible to fix with a different offset pulley? Possibly a single pulley Are there any other shimming suggestions or tricks I may be overlooking? There are some good ideas mentioned in the threads below but no conclusions. Looking for some advisement to continue with all the great help this site has proved me so far Reference articles: http://67-72chevytrucks.com/vboard/s...d.php?t=354622 http://67-72chevytrucks.com/vboard/s...power+steering http://67-72chevytrucks.com/vboard/s...d.php?t=408991 http://67-72chevytrucks.com/vboard/s...d.php?t=216886 |
06-17-2011, 01:10 AM | #2 |
Hand Crafted C-10
Re: I6 250 Power Steering Pump Alignment
If rest of the brackets are correct and you can't find answers here, I would try at one of the Chevelle forums.
I don't know what size 6 cyl he ran, but Brad (board name "Brad") had PS on his old '67 C-10 (I believe) plus on his 6 cyl stock Camaro. If you don't find your answer, perhaps shoot Brad a PM and ask him. |
06-17-2011, 12:47 PM | #3 |
It would be helpful if you would post some pics. There are different PS set-ups, so it's hard to tell what you're working with without seeing. Where did you get your set-up? Was it complete or did you piece it together?
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
06-17-2011, 06:22 PM | #4 |
I actually bought it off a board member here. It came with all brackets, pump and a double V-pulley.
I was able to snap a few quick pictures out the door this morning, but this should give a better idea of what I am working with currently. Also I looked it over again last night for possible solutions and it seems the easiest and most logical would be a different pump pulley to correct the offset. What I don't know is if the offsets really exist or if they are just different belt designs. Someone mentioned to me the offset wouldn't be effected much by just a different pump pulley |
06-17-2011, 07:41 PM | #5 |
I am a Referee of life.
I have two pumps sitting on the shelf in my garage.They are different pulleys.I think one came from a 69-70 truck and the other from an unknown source(but is from a 250/6 probably a Nova).They are both single groove pulleys,but have different offsets.One is dished deeper than the other.I have one complete sets of brackets and a partial.They are also different.I think I have enought to install and align the set-up but haven't had a chance to install yet.From a semi-mockup,it looks like one pulley will align but the other would be half a belt or like yours fall in the center of the two groove HB pulley.I also picked up about 5-6 different pulleys for the 250 to have on hand to work out alignment.Most I have talked to say it is hit or miss unless you buy a complete setup from a truck including HB and all pulleys.There were several different bracket/pulley combos for the 250 from what I can determine but I've only seen a couple styles on the trucks(factory style).IIRC the differences are dependent on whether the truck had A/C or not.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 06-17-2011 at 07:45 PM. |
06-17-2011, 09:19 PM | #6 |
Exactly what I wanted to hear lol
Looks like some trial and error with pulleys is in my near future, the pump and pulley itself are the same style for v8 motors as well correct? Believe I may have greater luck finding those Any other pulley source ideas is appreciated Posted via Mobile Device |
06-17-2011, 10:00 PM | #7 |
I wish you were close by.......We could throw one of my pumps with a single pulley on it and see if it lines up. One thing that might be an issue for you is the truck that this came off of before you got it might have had the crank & water pump pulleys changed at the time that PS was added to it.
04-14-2013, 03:06 AM | #8 |
Late update for future people looking for ideas
I was able to dial in the final alignment of the pulley by adjusting the brackets as much as possible and then created some keyed washers to go inbetween the power steering pump and the pulley itself. they fit over the pumps shaft and match the shafts built in key so they spin with the whole assembly. Just make sure you have plenty of thread to securely hold the pulley on the shaft when your done aligning
'68 SWB Stepside - Inline Long Six 250 C.I. (LS250): http://67-72chevytrucks.com/vboard/s...ferrerid=83901 |
