Old 06-16-2011, 08:53 PM   #1
Nobaddaze
Nobaddaze's Avatar
Pinion angle with Air bags
What are you airbagged guys running for pinion angle? What is the stock angle supposed to be?
I was told along time ago that you were not supposed to have your driveshaft in perfect alignment with the pinion...you always want it to be a couple degrees off?? Is this correct?
How about angle change throuhout the entire travel??
Any help would be awesome
Thanks Guys
Hard work has a future payoff. Laziness pays off now.
My Build
Nobaddaze is offline   Reply With Quote
Old 06-16-2011, 09:13 PM   #2
76stepsidechevy
Re: Pinion angle with Air bags
If it were me id set the pinion angles at whatever your ride height will be, usually the pinion gets set 1-2 degrees down to compensate for axle wrap under acceleration.
76stepsidechevy is offline   Reply With Quote
Old 06-16-2011, 10:53 PM   #3
njlimbaugh
The output shaft on the tranny should be at the same angle as the input on the diff with the truck sitting empty and the air bags set for road travel.
njlimbaugh is offline   Reply With Quote
Old 06-17-2011, 11:09 AM   #4
Nobaddaze
Nobaddaze's Avatar
Thanks guys...Im designing a 4 link in solidworks and i wanna get it as close as possible before i start building. I appreciate the input
My Build
