Old 06-17-2011, 12:22 AM   #1
fanmanj
fanmanj's Avatar
Replacing turn signal stalk/cruise switch
Ok, well, I'm trying to swap out my turn signal stalk/cruise control switch with the one I yanked out of an '83 'burb in the junkyard.. It was easy to remove, just disconnected the wires and a slight tug had them out of the column. Now I'm trying to put this on my '86.. Is there any way to run this wire down the column without tearing the column apart??
Jay Bernard, Thibodaux, LA
1986 SWB Sierra Classic
Stock roller 350/700R4
2008 Buick Enclave CXL
3.6 VVT, 6spd auto.
PAINFULLY stock... (wife's ride)
fanmanj is offline   Reply With Quote
Old 06-17-2011, 02:25 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Replacing turn signal stalk/cruise switch
Yes. You can do it with a stiff small gauge wire and some patience. I have a piece that I took out of a spring set on an old bench seat and it works quite well for things like this. The wire is pretty rigid.
Frank
piecesparts is offline   Reply With Quote
