No Dash lights
Just got done replacing the headlight and dimmer switches on my 67 1/2 ton and have no dash lights now. Any Ideas on what it could be.
Re: No Dash lights
Dumb answer (no offense intended). Is the dimmer knob rotated to off?
When I bought mine, they didn't work. Found out all were burned out.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
![]() Join Date: Nov 2010
Re: No Dash lights
Bad new switch? I got a bad "new" switch right outta the box from the parts store once. Check the fuse to the cluster too.
Re: No Dash lights
Is the Fuse to the cluster in the fuse box or seperate
Re: No Dash lights
In the box. Can't remember which exact one right off hand. I'd have to look at mine to remember.
Re: No Dash lights
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: No Dash lights
It's labeled "pnl lights on the fuse box and is fed by a green wire from the head light switch. There is a gray wire from the fuse panel to the gauge cluster that feeds the lights in the cluster and also the heater control light and the glove box light.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: No Dash lights
Thamks. looks like I need change the fuse after work
its all about the +6 inches
Re: No Dash lights
it is actually double fused... the fuse that runs the brake lights and parking lights also runs the dash lights
