Old 06-17-2011, 02:02 AM   #1
oldspowered67C10
19" wheels
Looking for pictures of trucks with 19" wheels. Would really like to see 19"/20" combo but 19" all the way around will work too. Thanks.
oldspowered67C10 is offline   Reply With Quote
Old 06-17-2011, 02:10 AM   #2
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: 19" wheels
I didn't realizze they made a 19inch wheel, so I'm in to see these, 12-18, 19.5, 20, 22.5, but I may be wrong
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-17-2011, 02:33 AM   #3
TrkEnvy
Re: 19" wheels
They make em.. My moms AMG benz has 19s on it but I doubt they make any for our trucks. I cant tell the difference between a 20 and a 19.. so why 19s??
TrkEnvy is offline   Reply With Quote
Old 06-17-2011, 04:17 AM   #4
hdzammo
hdzammo's Avatar
Re: 19" wheels
I ordered some 19s but haven't gotten them yet. I'm going with a 5/7 drop so I thought having an extra inch for rubber would be better.
hdzammo is offline   Reply With Quote
Old 06-17-2011, 04:53 AM   #5
oldspowered67C10
Re: 19" wheels
I want the staggered look but I think 2" stagger is a bit much. Besides, I dont have a big enough notch in the rear to run 22s in the back and have it sit the way I want and its too hard to find the tire width I want in a 21" tire.
Old 06-17-2011, 08:07 AM   #6
68Stepbed
68Stepbed's Avatar
Re: 19" wheels
Do a search for PCHRODS. He has a Burgundy/Black 67 with 19's.
Edit-Here ya go. http://speedhunters.com/archive/2010...hevy-c-10.aspx
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-17-2011, 08:26 AM   #7
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: 19" wheels
Yep, there are 12-18, 19, 20, 21, 22, 23, 24, 26, 28, 30 (and of course the 16.5, 17.5, 19.5, 22.5, 24.5)
19s aren't very common though, mostly only on higher end European cars and a small part of the aftermarket. I remember when I toured the BMW facility in SC back in highschool almost 10 years ago, I did a double, then a triple take when I read 275/30R19 on the sidewall of a tire on a 5 Series.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 06-17-2011, 08:43 AM   #8
laplander
Re: 19" wheels
I remember when a new 1984 Corvette showed up at our Chevy dealership and all my friends and I went in to check it out and were blown away by the 255/50/16 tire. 16!?! Holy crap, that 16" rim is huge. LOL. My how times change...
laplander is offline   Reply With Quote
Old 06-17-2011, 08:49 AM   #9
GCncsuHD
GCncsuHD's Avatar
Re: 19" wheels
Did yall get any 1983 Vettes?
ΜΟΛΩΝ ΛΑΒΕ
Old 06-17-2011, 10:50 AM   #10
YBNORML
YBNORML's Avatar
Re: 19" wheels
They may make 19" tires and rims, however be careful to find some with the proper rating suitable for use on a truck. It does make a difference in the ride quality. Even if you don't carry anything in the truck.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 06-17-2011, 11:12 AM   #11
GCncsuHD
GCncsuHD's Avatar
Re: 19" wheels
Agreed, but most sizes large enough to fit truck wheel openings will probably be rated enough for use on a truck. Remember Mercedes and BMW SUVs came stock with these size tires and weigh more to start with than our trucks as well as being rated for towing light loads as well.
While I don't think 19" tire sizes are "load rated" many of their weight ratings in those sizes rank up there with general Load Range C tire ratings of ~2500lbs per tire giving 10,000lbs of load carrying ability which is much larger than the GVWR of our trucks anyway. Also remember the tire has to be inflated to a certain pressure to carry that weight. It may be rated at 2500lbs at 50psi, but at 35psi the ride may be more comfortable, but it would only be good for maybe 1600lbs or so at that pressure, and too much weight would cause the tire to heat up, wear faster, and possibly cause a blow out. But again, say it was good for 1600lbs at that pressure, it would still be good for 6400lbs overall, which is still above the GVWR of the truck.
ΜΟΛΩΝ ΛΑΒΕ
Old 06-17-2011, 11:12 AM   #12
Ackattack
Ackattack's Avatar
Re: 19" wheels
Also, generally speaking 19" tires are much more expensive than 18" or 20" and your choices are more limited.
Ackattack is offline   Reply With Quote
Old 06-17-2011, 11:22 AM   #13
fastcam1
Young gun
fastcam1's Avatar
Re: 19" wheels
Classic trucks had an issue bout 5 or 6 years back you can still find it on their web site the guys name was Spencer Osbourne it was a 71 swb c10 with 19" in front and 20" out back totally beautiful truck I've seen in person at the good guys show
Here's the link
http://www.classictrucks.com/feature...c10/index.html
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 06-17-2011, 11:24 AM   #14
hdzammo
hdzammo's Avatar
Re: 19" wheels
They are more expensive but not by much. For a set of four for me it was about 100 more for the four tires.
Old 06-17-2011, 11:25 AM   #15
Frizzle Fry
Frizzle Fry's Avatar
Re: 19" wheels
Thanks for posting that fastcam1! That's one of my all time favorites!
Frizzle Fry is offline   Reply With Quote
Old 06-17-2011, 12:25 PM   #16
TacBlade
Re: 19" wheels
Here are some 18"
TacBlade is offline   Reply With Quote
Old 06-17-2011, 02:46 PM   #17
fastcam1
Young gun
fastcam1's Avatar
Re: 19" wheels
Ya its definitely in my top three its the one that started my addiction though still have the issue in my garage lol
Northwest C10's
Cameron sparks
