Old 06-17-2011, 03:21 AM   #1
TheApocalyptican
TheApocalyptican's Avatar
Add to fan shroud or use fan spacer
I am looking for ideas on what to do with my Suburban. It has a 454 4 row rad and shroud with a 350 engine. Due to this the fan isn't far enough in the shroud. I can't use most fan spacers, as they are meant for flex fans that don't have a clutch. Anyone know of a spacer meant for clutch fans?
Or, I was thinking of maybe adding a strip of aluminum around the shroud to make it deeper, but don't know where I would even look to be able to get something like that.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 06-17-2011, 05:32 AM   #2
S10Fan
Old Heap Driver
Re: Add to fan shroud or use fan spacer
A picture or two would be helpful, but if you can't I understand. Aluminum pieces can be found at Lowes or Home Depot. How far into the shroud is your fan?
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 06-17-2011, 09:36 AM   #3
geeforcem
I have the exact same set up on my C10.. Hayden makes a 1in fan spacer that put the fan 1/2 in and 1/2 out of the shroud. I noticed a huge difference in cooling on the gauge and a/c efficiency after i installed it.
jeff
Jeff
1986 Chevy C10 Custom Deluxe swb
1983 Chevy Silverado swb stepside, factory 6.2/700r4
2002 GMC Sierra SLT
1979 GMC Jimmy High Sierra
1978 Chevy C10 Big 10 lwb Scottsdale
geeforcem is offline   Reply With Quote
Old 06-17-2011, 09:35 PM   #4
TheApocalyptican
jeff
Do you happen to have a part number? The only thing I have found from hayden is a flex fan spacer that while the spacer is great....the bolts are too long to be able to get into the holes of the clutch due to the clutch itself being in the way.
Right now the fan is maybe 1/32" to 1/16" into the shroud.
Old 06-17-2011, 11:01 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Studs in the water pump?
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-17-2011, 11:43 PM   #6
TheApocalyptican
Not sure if you're maybe asking about trying it that way?
Currently, there are studs in the water pump. About 1/2" worth that threads into the pump, and about 3/4" worth that are what are used to bolt the pulley and clutch onto. My only concern with the studs is being able to find some that have the flared out un-threaded part with a longer threaded portion on front.
Old 06-18-2011, 01:25 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Yeah get longer studs for the spacer. Fastenal oughta have them.
