Old 06-17-2011, 12:28 PM   #1
72tutone
rear window replacement adhesive?
Is is required to put adhesive on the seal or on the cab when replacing the rear window? I would assume the seal is good enough, but want to check first.
72tutone is offline   Reply With Quote
Old 06-17-2011, 01:11 PM   #2
Katrina/10
Katrina/10's Avatar
Re: rear window replacement adhesive?
I put a new gasket on my rear window and it still leaks. Interested if there is a sealer that can be applied to fix this.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-17-2011, 06:02 PM   #3
AirSpeed
AirSpeed's Avatar
I have replaced three rear windows in my trucks and have never used any sealer, same thing with the windshields. As long as you get a quality rubber seal you should have no problem. When I painted my last truck I bought a new windshield and rubber and it leaked in the lower right corner, I pushed the rubber seal around and the leak stopped immediately.
You should be fine without any sealer. Who ever replaced the windshield in my truck before I bought it used sealer, everywhere he used it the windshield frame rusted, it took forever to scrape it all out and clean up the rust. I think sealer would actually make things worse by holding water and dirt in there.
AirSpeed is offline   Reply With Quote
Old 06-17-2011, 06:10 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i used ky jelly and string
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-17-2011, 07:32 PM   #5
Willys47
Willys47's Avatar
that is just too much info for me
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 06-17-2011, 09:28 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Originally Posted by AirSpeed View Post
......Who ever replaced the windshield in my truck before I bought it used sealer, everywhere he used it the windshield frame rusted, it took forever to scrape it all out and clean up the rust. I think sealer would actually make things worse by holding water and dirt in there.
It isn't the sealer, per se, but the KIND of sealer. If you use a silicone sealant, be absoutely positive that it is an automotive variety. Silastic, a silicone sealer/adhesive, gives off glacial acetic acid, as it cures. That acid will cause rust. My '69 cab had what must have been about three tubes of it, daubed everywhere it didn't need to be. My firewall was swiss cheese.
Glass shops nowadays, use urethane. I don't think we need it for the gaskets in our trucks, but I'm sure someone on here knows for sure....whether we need anything, or nothing. Nothing would be better than the wrong thing. Maybe some 3M weatherstrip adhesive is all we need, and I know it's an automotive grade.....yeah, that stuff we also call "snot" in a tube. Use the black, though.
Here's what the GE Silastic will do:
Member Nr. 2770
