Old 06-17-2011, 02:23 PM   #1
Squareforceone
Squareforceone's Avatar
Insulation in the vents?
There is insulation in the vents of my '84 c10 that blows out every time i try to turn on the ac any tips on how to get rid of it. i mean yes take of dash and shop vac out the insulation but tips to keep if out of there do i have replace it all?
Squareforceone is offline   Reply With Quote
Old 06-17-2011, 02:53 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Insulation in the vents?
don't usally see it IN them but maybe the PO had a air flow he didn't like and stuffed it in
in the valve ajustment for the floor to def there is ajustment inside (air box) with a rod to move inside,(3 poss spots) this makes most of the air go up or down,but in the middle is all up or down.
i'd say remove the air box ,make sure it's sealed ok@the firewall too
is it foam or material chunks?seen the blender door seal spew chunks too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-17-2011, 03:41 PM   #3
tucsonjwt
Once you clean the ducts out, seal the hose connections to the plastic vent fittings with residential HVAC aluminized duct tape (the expensive shinny kind, not regular duct tape.) The hoses just barely fit on to the ends of the fittings, so they slip off very easily. You will have to have the dash pad off in order to reach down and apply the tape to seal the connections. You will also have to remove the glove box and probably the cigarette ash tray.
tucsonjwt is offline   Reply With Quote
Old 06-17-2011, 03:41 PM   #4
xrcr
buy a mouse trap
xrcr is offline   Reply With Quote
Old 06-17-2011, 04:51 PM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
Originally Posted by xrcr View Post
buy a mouse trap
My thoughts exactly.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 06-17-2011, 05:18 PM   #6
76stepsidechevy
I know mine is full of rotting foam from the blend door. I think most of it is gone now but the only way to be sure is to take it apart and clean it.
76stepsidechevy is offline   Reply With Quote
Old 06-18-2011, 08:20 PM   #7
cr34t3d_by_d4rkd3n
tear it apart, chances are ur gonna wanna clean any ways, i found nasty things..... and the dust is like powder-y.... nasty stuff.
cr34t3d_by_d4rkd3n is offline   Reply With Quote
