Old 06-17-2011, 04:37 PM   #1
83highsierra
83highsierra's Avatar
oil pressure and battery gauge, rpm tach install
ok so im wanting to install oil pressure gauge, rpm tach, and battery gauge ok how do i do it
thanks
83highsierra is offline   Reply With Quote
Old 06-17-2011, 04:54 PM   #2
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: oil pressure and battery gauge, rpm tach install
All aftermarket, I presume? Are you going mechanical or electronic? And do you want your stock guages to still work (if they even do right now)?
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 06-17-2011, 05:03 PM   #3
83highsierra
Im going mechanical and aftermarket right now and currently i just have a light behind a sticker on my dash
Old 06-17-2011, 05:06 PM   #4
83highsierra
Also wanting to do coolant temp
Old 06-17-2011, 05:13 PM   #5
lindstromjd
Mechanical is super easy to install. Oil pressure goes right behind the intake on the back driver's side of the engine. There's a port for it there, but is probably blocked off. You'll need to heat up the plug to get it out.
Water temp goes on the driver's side head, near the front of the engine. You can put it in one of the ports on the intake if you have any, but don't put it in the water neck. You'll get false readings if you ever lose any of your coolant.
Alternator guage will just hook up to a switched power wire, and have a good ground. (Even a "mechanical" one of these gauges is still electric).
Tachometer will be the tricky one... what kind of distributor do you have? If you've got an HEI, then it's really simple because they have an output for a tach reading that you can just plug the sender for the tach into. If you don't, then I'm at a loss to how to hook one up. Someone else will have to chime in on that one.
-357 / 700r4
-350 / TH350
Old 06-17-2011, 06:01 PM   #6
83highsierra
any chance photos can be provided im a visual person
Old 06-17-2011, 06:12 PM   #7
lindstromjd
I can get pictures, but it wont be until tonight when I get off work. Unless someone else has any?
-357 / 700r4
-350 / TH350
Old 06-17-2011, 06:13 PM   #8
83highsierra
thanks i appreciate it
Old 06-18-2011, 12:54 AM   #9
lindstromjd
Top picture is the driver's side head where the water temp gauge goes. Bottom picture is where you get your oil pressure from.
-357 / 700r4
-350 / TH350
Old 12-17-2014, 01:00 AM   #10
jb3t
There are some pics here... http://67-72chevytrucks.com/vboard/s...d.php?t=652293
Also try you tube.
jb3t is offline   Reply With Quote
