Old 06-17-2011, 08:02 PM   #1
harnalien
TruckincrazY
harnalien's Avatar
Cooling System at Startup Help
Well I finally got my truck to turn over the other day. It sounds strong, but we noticed a major problem with the cooling system. Basically, it seems the pump is not pushing coolant through the system. We took the pump off and it rotates fine and does not have any metal or binding issues. The pump on LQ4's rotate counter clockwise right? I have the belt routed the way I have seen others route theirs. The engine did not have any coolant in it when we installed it. We tried to put coolant in it, but couldn't get an entire jug of in it without overflowing the radiator. We figured that when the motor started, the pump would start to suck and circulate the coolant, then we would just fill it back up. We plan on reinstalling the pump tomorrow and trying to pour fluid directly into the upper water neck so it gets into the pump and engine...kinda priming the system. Does this sound right? The bottom radiator hose had fluid, but the top one was bone dry. Please help me figure this out! I'm hoping it's something dumb I'm overlooking. It's been about 2 months trying to get this thing running. ('04 6.0 into an '84 2wd shortbed).
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 06-17-2011, 08:43 PM   #2
TR65
TR65's Avatar
Re: Cooling System at Startup Help
harnalien,
I am not an expert on this but do you have the steam vent routed to somewhere high on the radiator? Seems like most of my air came out of that vent when I was filling. If nothing else, open it down at the head and see if coolant will go in. I could get most of the coolant in, 3+ gallons as well as I remember, my engine was empty also.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-17-2011, 08:46 PM   #3
clinebarger
Take the upper hose off at the radiator, Turn the hose upright & pour the coolant into the hose, LS & LT engines are reverse flow (The thermostat is on the bottem hose) & the coolant flows bottom to top in the radiator.
clinebarger is offline   Reply With Quote
Old 06-17-2011, 08:56 PM   #4
harnalien
TruckincrazY
harnalien's Avatar
Thanks guys, that's what we were planning on doing tomorrow; pour coolant into it via the uppor hose. I wish I had thought of that before I took the dang pump off. We were sure it was bad.
Old 06-17-2011, 09:03 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I almost burned mine up figuring this out...guess I should have done more reading.
Fill up the radiator only and you don't get coolant into the motor. hmmm...sounds right???
once I poured coolant into the top of the block, the system opened up shortly after and began flowing.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-18-2011, 12:52 AM   #6
85burb
85burb's Avatar
I filled mine up from the rad. and have had no problem at all. Have put over 70 hours on it so if it was not getting coolant it would have died by now. It is 100 degress here to. Interesting tho.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 06-18-2011, 02:21 PM   #7
harnalien
TruckincrazY
harnalien's Avatar
Got the pump back on, filled it from the top hose and fired it up. Now I've got a leak somewhere. I thought it was from the front drain plug, but it's tight. I think/hope it's coming from the steam line, but I can't tell. I'll have to look at it tomorrow. This is really starting to suck.
Old 06-19-2011, 12:24 PM   #8
Super73
Super73's Avatar
The LS is not a reverse flow like the LT. True it pulls the coolant from the lower radiator hose, but it is not a reverse flow. In other words, the coolant flows to the block then the heads, just like the traditional small block. The LT's actually cool the heads prior to cooling the block. LT's are a true rverse flow.
You definately want to fill the motor up using the upper radiator hose trick.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-19-2011, 09:20 PM   #9
clinebarger
GM got sued by Evans over the rights to the "Reverse Flow Cooling system" http://money.cnn.com/magazines/fsb/f...3431/index.htm
And according to the diagram below & everything else ive read....Your right.
BUT...There is a BIG problem with this diagram! It shows the coolant from the radiator flowing through thermostat into the engine. How would that work? The cooler water from the radiator would close the thermostat before all the hot water got out of the engine. If we reverse the flow on the diagram...It would be a perfect example of a "Reverse flow Cooling System" & the thermostat would work like every other thermostat Ive ever seen.
My theory is LS engine are reverse flow...Untill someone explains how a thermostat can operate on the suction side of a cooling system, I stand by what I stated earlier.
Old 06-20-2011, 02:30 AM   #10
Super73
Super73's Avatar
You can stand by what you said, but I can tell you from experience, the above diagram is correct. Go pull the upper radiator hose off any LS motor and fire it up. You won't get much if any movement until the T-stat opens. Then you have a fire hose till you run the radiator dry.
This is the very reason that priming the motor with water before fire up is very important (pooring it down the upper hose).
Old 06-20-2011, 05:15 PM   #11
gopokes
gopokes's Avatar
I'm glad I read this post, the first few times I fired up my engine I had only filled up the radiator, then rechecked the water lever, since it didn't go down, I assumed the engine was full of water already. I filled it this weekend from the top hose, took a little over a gallon. Glad I never let that thing run more that a little bit.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 06-21-2011, 01:56 PM   #12
Shon
might have hit the steam line and cracked it..it happens or the clamps used are not working correctly.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 06-21-2011, 11:00 PM   #13
Super73
Super73's Avatar
Also double check the o-rings are in the steam line plugs or the surface that mounts the steam line to the heads. If they are there, make sure they are not torn.
