Old 06-17-2011, 10:55 PM   #1
Cobblemizer
Control arm help
I have a cracked lower control arm on the right side lower and I was wondering if 73-87 lower control arms could be swaped into a 1963
2wd 1/2 ton without changing the cradle.
Cobblemizer is offline   Reply With Quote
Old 06-17-2011, 11:53 PM   #2
blackedoutharley
Re: Control arm help
No... they are not a replacement part for the '63. Use different bushings and ball joints.
blackedoutharley is offline   Reply With Quote
Old 06-18-2011, 12:54 AM   #3
Captainfab
60-66 Nut
You can use those if your '63 is a C10, and you are switching to disc brakes at the same time. If you are staying with drum brakes, you will need a LCA from a '63-'72 C10.
Old 06-18-2011, 07:07 AM   #4
Cobblemizer
Thanks for the help, but I have another question.
If I go with the 73-87 lower control arms and 73-87 spindles, do I have to change the upper ball joints as well to match the newer spindles?
Old 06-18-2011, 09:49 AM   #5
badblu97
Double 6's
badblu97's Avatar
Yes, the 73-87 balljoints I believe have a larger stud, but if they have been replaced in your uppers already, they bolt in, so no big job. The balljoints must match your spindles....
Street Glidin!
1966 LWB Custom Cab (sold)
1982 Short Fleet (under the knife)
1998 S10 2wd Fleet
2007 Chevy Silverado Crew
2007 Harley Davidson Street Glide
badblu97 is offline   Reply With Quote
Old 06-18-2011, 10:56 AM   #6
Captainfab
60-66 Nut
Why not change the upper control arms to the '73-'87 style also? That way you have the same style control arm bushings on all control arms. Also there is a chance that the ball joints are useable. Of course it is a good idea to replace the ball joints while it is appart, but if you're on a budget, that would get you by for a while.
Oh, and if you change to the '73-'87 LCA's, drill out the holes in your crossmember and use the larger diameter '73-'87 LCA shaft U-bolts.
