06-18-2011, 12:20 PM | #1 |
radio help
ok so installed a new sound system in my truck new wires new amp new speakers new deck hooked the deck up to the same power sources that the PO had his radio connected to...the radio doesnt turn off with the ignition i have to turn it off manually
..my question is....where on the fuse box should it be hooked up to so that it turns off with the ignition |
06-18-2011, 01:08 PM | #2 | |
Re: radio help
06-18-2011, 05:38 PM | #3 |
Re: radio help
ok thanks
06-21-2011, 10:46 PM | #4 |
Chevys Kick A$$
Re: radio help
Yep just what he said. You can test the wire that was hooked up but sounds like it is not ignition hot. You should just be able to run the usually yellow constant wire to your fuse box some where. If you have a tester light just find one that has power when the keys on.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
