Old 06-18-2011, 01:12 PM   #1
krazy_texan
krazy_texan's Avatar
Rebuilding the 12bolt rear in my 65
Ok so my 65 has a bad seal on the driver side which has made a huge mess inside the brake drum. Well I have pulled axle shafts out a truck before but never removed the ring gear or anything like that but I am thinking of rolling the axle out of the truck and rebuilding it completely from end to end new brakes and drums and all new bearings and seals then painting the axle and reinstalling it with new u bolts and the whole setup so being as I have never completely done this I am seeking advise maybe seeing if there is anything specifically I need to do or pay attention to
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 06-18-2011, 01:32 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Rebuilding the 12bolt rear in my 65
If you have not rebuilt a center section of a rear, I would suggest a pro do it. There is more than just replacing parts. Not knockin your abilities, but its not as easy as it seams.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-18-2011, 03:00 PM   #3
Shaky
Six in a row makes it go...
Shaky's Avatar
The hardest part is setting pinion depth. It takes some specialized tools.
Next hardest is the crush sleeve for setting the pinion bearings.
After that its setting the gear backlash.
I did mine with all new gears, bearings, and posi unit. It took me quite awhile, but I'm somewhat of a perfectionist when it comes to that stuff.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 06-18-2011, 04:04 PM   #4
A.T. RockDriller
A.T. RockDriller's Avatar
Krazy Tex....
If you have some experience with this rear diff and aren't afraid of a little bit more of a challenge....you can think about the following;
It isn't out of line to expect 500K miles or even more out of a well set up ring & pinion.
If you aren't hearing or experiencing any gear related symptoms.....and you are thinkin' you want to o-haul this thing, then have at it......and reuse the gear-set that you have.
You'll need a brg splitter, a large press, an inch pound torque wrench and an impact wrench.
Take care to retain the carrier shim-packs in order by side and the pinion shims by position. You'll need to replace the crush sleeve, so follow the instructions carefully and you shouldn't have any problems.
You should be able to replace every brg. and seal in the whole diff. and reassemble it to the same tolerances without any problems.
The gears will mesh as they did before as long as you keep track of your shims.
Then you can paint to your hearts content.....
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
