"the other guy"
temperature sender help needed
i have a little issue on my hands. i need a part# or application for a temp sender to use with vortec heads and stock gauges in my 67. the pipe hole in the heads is i believe 3/8npt and the stock sender is 1/2npt.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Re: temperature sender help needed
My aftermarket World heads have 3/8 NPT holes for a sending unit. The POs sender was the wrong range. I ended up using a 1/2 NPT sender and installed it in the intake manifold. NAPA Echlin has a catalog you can wade through (it is a beeeyeteeseeaych to download http://www.napaechlin.com/upload/NAP..._NA141_HQr.pdf) and perhaps find a 3/8 NPT unit that will work. I gave up and went to 1/2 NPT.
Check Posts #19 and #20 in my project thread. This isn't the solution if you want to stick with a 3/8 NPT unit, but I hope it helps you a little.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 06-19-2011 at 10:28 AM. |
I taped my vortec head to use the stock sender.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
"the other guy"
i would love to do the same, but mine are installed. maybe grease on the drill bit and tap?
