06-19-2011, 01:17 AM | #1 |
Brake Booster vacuum hose Location
Im converting to power brakes and was hoping for a description and pic of where the check valve booster line (vacuum hose) connects to. Im assuming that it connects to the intake manifold. Not sure where or how. Stock V8 350.
Thanks in advance Ryan |
06-19-2011, 02:39 AM | #2 |
Re: Brake Booster vacuum hose Location
I guess you could do it on the intake but on a stock 350 I think it goes on the main vac on the back of the Q-jet.
72 Cheyenne Super 80 Silverado Blazer 2wd |
06-19-2011, 03:19 AM | #3 |
~Rest In Peace~
off the intake will be fine
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-19-2011, 06:42 AM | #4 |
Watch out for your cornhole !
If you engine is all stock, there will be a plug on the back of the carburetor that you remove and install a fitting in it's place.
06-19-2011, 07:02 AM | #5 |
454 MAKES IT ROAR
Mines off the back of the carb.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
06-19-2011, 07:31 AM | #6 |
laying low
Back, base of the carb is correct. There should be a stronger vacumn signal there as you have pull from all 8 cylinders rather than just 1 or 2 from the intake runners.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
06-19-2011, 10:02 AM | #7 |
factory stock on the ones i've worked on has been a vaccume tree located in the manifold dead center a few inches in back of the carb// the pvc has been hooked to the carb port
that's what is shown in the factory assembly manual too
06-19-2011, 11:30 AM | #8 |
Thanks again guys, big help.
06-19-2011, 08:19 PM | #9 |
454 MAKES IT ROAR
One more thing...mine has this filter mounted inline of the hose running from the carb to booster, apparently it is to filter out the gas fumes to prevent them from perishing the rubber inside the booster.
06-19-2011, 08:20 PM | #10 |
That's not a filter, it's a check valve to hold vacuum in the booster when the engine's vacuum signal falls too low for any reason.
06-19-2011, 08:36 PM | #11 | |
454 MAKES IT ROAR
The link shows the exact same part as is in my booster. http://beaya1983.factory.dhgate.com/...t37082358.html
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 06-19-2011 at 08:52 PM. |
06-19-2011, 09:07 PM | #12 |
The part in your hand, duh. I immediately looked at the end of the hose and said check valve.
Carry on.
