Old 06-19-2011, 07:38 AM   #1
skysoldier173rd
skysoldier173rd's Avatar
15" Aluminum Slots
Does anyone of any companies making these today or where i could get a couple? I picked up 2 off EBAY and am looking for two more. Don't care what brand. I see American Racing does have what they call "Ansen Sprint" which is very similar but it appears they're only offered in 5 lug and i need 6. Several others like Indy used to make em, but can't find any current manufacturers.
skysoldier173rd is offline   Reply With Quote
Old 06-19-2011, 07:44 AM   #2
CaptHutch66
Ooops! Wonder what that costs?
CaptHutch66's Avatar
Re: 15" Aluminum Slots
Hard to find as far as the 6x5.5! Try www.craigsnation.com Good luck!
Hutch.....Metro Atl Fireman 29 years
1952 GMC 228 w/4spd Hydra Matic (SOLD)
1966 GMC stepside Shrtbed...350 w/Turbo 350 auto
CaptHutch66 is offline   Reply With Quote
Old 06-19-2011, 08:30 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
They are out there you just got to spend the time searching, swap meets, craigslist, ebay, even garage sales.....here is two sets in Nor Cal....same guy
http://sacramento.craigslist.org/pts/2445699623.html
http://sacramento.craigslist.org/pts/2445692385.html
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-19-2011, 10:55 AM   #4
taclem
taclem's Avatar
I picked up a set of 4 two years ago for $50.00 and a lot of elbow grease later they looked quite different from when I bought them. I am looking for a pair of 10" for the rear, I'll keep you in mind if I score them and sell you two of mine.
Taclem
taclem is offline   Reply With Quote
Old 06-19-2011, 12:05 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I picked up a set of 15/7 cleaned up em and was going to use em the other day (just finished my 5 lug swap) but the tire man said it takes special lug nuts?
So im runnin rallys for now.
Wash, scrub,spray eagle 1 etching mag cleaner, then hit with mothers alumninum polish
wish i flied on the lips and sanded a little (pretty rough)
John
1999 Toyota Tacoma 4x4
Old 06-19-2011, 12:06 PM   #6
oldblue1968chevy
left is after sprayed with eagle 1 etching mag cleaner, right is after some polishing
John
Old 06-19-2011, 01:33 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
It appears American Racing does make the Ansen Sprint in 6x5.5 bolt circle:
http://www.americanracingwheelsinfo....t_Slot_Mag.htm
15x7 – part number A695783
http://www.jegs.com/webapp/wcs/store...rm=286-a695783
15x8 - part number A695883
http://www.jegs.com/i/American+Racin...95883/10002/-1
Old 06-20-2011, 06:46 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You have factory Jeep slot mags. Try searching for Jeep wheels on ebay.
I've run them on a few of my trucks before. It's a great way to get some cheap 6 lug slot mags. Funny thing is I typed in "Jeep slot mags" into Google to find a picture for you and my old Suburban popped up as the 4th picture on Google.
Old 06-20-2011, 07:58 AM   #9
lakeroadster
I bought my US Indy 15x10 slot's from this place, they deal in old wheels: http://www.akhwheels.com/pages/showWheel.php?pk=137
lakeroadster is offline   Reply With Quote
Old 06-20-2011, 11:20 AM   #10
oldblue1968chevy
Can somone tell me the type of lugnuts I need to run these?
My old tire man at a sweet little mom/pop tire shop said I need new ones to run em
Also, is there a lugnut I can use to run slots/rallys?
John
Old 06-20-2011, 01:34 PM   #11
lakeroadster
There are almost as many different lug nuts as there are designs of wheels. Aluminum is soft and most aluminum wheels use a lug with a washer. The lug bears against the washer, the washer bears against the face of the aluminum wheel.
Factory rally wheels are steel and typically use a conical lug that pushes against the conical machined hole in the wheel hub.
Post up a close up photo of the hole in your aluminum wheel.
Old 06-20-2011, 09:19 PM   #12
Rich 5150 69
Also need to keep in mind that there are those infamous unilug slots out there, even new they were treacherous....if you ever encounter them run away....
Old 06-20-2011, 09:33 PM   #13
lakeroadster
Agreed. But feel obligated to mention there are exceptions to that rule. I had a set of Cragar Mach 8 aluminum slots (8 holes instead of 5). They were uni-lug but had an aluminum die cast adapter ring that slipped into a machined boss in the back of the rim that was used to change the bolt pattern. It fit real snug and worked great. Never had any problems keeping the wheel/tire combo's in balance, and was running L-60-15's.
Old 06-23-2011, 10:00 AM   #14
jchav62
1962 C-10
jchav62's Avatar
Saw these over on the HAMB...
http://www.jalopyjournal.com/forum/s...d.php?t=533549
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-23-2011, 10:45 AM   #15
blackedoutharley
Luckily, until the introduction of the Dodge Dakota & GMC Envoy/Chevy Trailblazer's all 6 lugs were 5.5" circles so no need to drill the wheels for other patterns.
As such, the slots mags should take a simple shank style mag lug nut with washer.
Make sure the lug nut is not so long that it sticks out past the wheel or it will bottom out on the hub and not properly tighten the wheel down (that can be bad trust me). Also the washers go on the lug nuts a specific way (flat side towards wheel).
blackedoutharley is offline   Reply With Quote
Old 06-23-2011, 12:46 PM   #16
ratskin
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
ratskin is offline   Reply With Quote
