Old 06-19-2011, 12:37 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Strong arms and stock sway bar??
Is it possible to run a stock chevy truck sway bar with mt air ride strong arms or do I need to buy a sway bar from airride??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-19-2011, 12:40 PM   #2
Rochlow
Re: Strong arms and stock sway bar??
Contact Porterbuilt... He has a cheaper solution than Airrides $500 swaybar. I got one from him and it was less than half that price.
Rochlow is offline   Reply With Quote
Old 06-23-2011, 11:11 AM   #3
craig@ridetech.com
Formerly LSC71
To answer the question, no the factory sway bar will not work. When we originally designed the strong arms we converted the sway bar mounting to the new posi link end links we have. This way we were able to get better transfer of motion from the control arm to the sway bar. It also allowed us to custom build a better sway bar for those trucks as well. We have them available for $400 or contact any of our vendors on the forum to get you set up. Thanks!
craig@ridetech.com is offline   Reply With Quote
Old 06-23-2011, 11:46 AM   #4
tech@scottshotrods
dang craig you beat me two it.... hahahahahha We are offering a pretty good discount on the Ridetech swaybar for the month of June...
tech@scottshotrods is offline   Reply With Quote
Old 06-23-2011, 02:26 PM   #5
SCOTI
SCOTI's Avatar
Was there a specific reason the Ride Tech C10 sway-bar wasn't built to the HD GM bar size (1.25")?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-24-2011, 03:28 PM   #6
craig@ridetech.com
Formerly LSC71
Our sway bar is built to 1.25" od. Not sure if there is some bad info out there somewhere but they have been that size from the start. We did originally use a hollow tube bar, but the current design is a solid heat treated chromolly steel. Featuring an average tensile strength of 170,000 psi. These are the best bars you can get in my opinion.
Old 06-24-2011, 03:34 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
Looks like Ill have a stock sway bar for sale as for the 400 bucks for an aftermarket one looks like Ill wait until the truck actually sees pavement before I buy one...
MEMBER #6377
Project "7DEUCE"
Old 06-24-2011, 07:22 PM   #8
SCOTI
SCOTI's Avatar
I'll re-check mine....
I was pretty sure it was smaller than 1.25" because I remember thinking to myself if I would have known it was smaller than the OE HD bar, I would have used someone elses.
(edit) Just came back in from checking.... mine is 1.125".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-27-2011, 04:17 PM   #9
craig@ridetech.com
Formerly LSC71
If this is one that we sold you then shoot me an email I'd like to know more about it. craig@ridetech.com Thanks!
Old 06-27-2011, 06:13 PM   #10
SCOTI
SCOTI's Avatar
Yep. Although it was a few years ago, I got it from you guys when I got the a-arms. I was under the impression then that it was 1.25" OD.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-28-2011, 10:05 AM   #11
craig@ridetech.com
Formerly LSC71
Well yeah it should've been, that's why I'm surprised that it isn't. I know it's only .125" difference but it is still not what it should be. I'd be willing to trade you out for a new one if you want.
Old 06-28-2011, 12:35 PM   #12
tubbedII
needs more $$$
tubbedII's Avatar
Just had to say that's awesome...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
