06-19-2011, 01:07 PM | #1 |
Removing a SM465 shift lever
I need to pull the 292/sm465 out of my 68 & can't figure out how to remove the shift lever. Can anyone provide some help & a few pics would be great. TIA!!
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
06-19-2011, 01:19 PM | #2 |
Re: Removing a SM465 shift lever
If I remember correctly you push down on the round cover at the base of the shifter and turn it a quarter turn. Chris
06-19-2011, 01:20 PM | #3 |
Push down on the coller with a pair of vise grips & turn it 30 degrees counter clockwise. It should come right out.
06-19-2011, 01:20 PM | #4 |
Just like to part out trucks!!
Bryan, there is a metal collar around shifter, push it down and turn it counter clockwise, and it should release. Only needs to go like a quarter turn
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 06-19-2011 at 01:20 PM. |
06-19-2011, 04:48 PM | #5 |
I always put it neutral first, makes it easier going back.
06-19-2011, 07:09 PM | #6 |
Thanks a bunch you guys. Once I cleaned up the top better I could see the groove where that collar seated. Just used my gigoondo channel lock pliers & she turned a little then a wiggle on the stick got everything to pop loose & up. Appreciate the fast responses cuz they were also spot on!!
Got the 292/4spd about ready to pull now - front is open & all the connections are free.
