Old 06-19-2011, 03:40 PM   #1
celcius232
5 x 4 3/4 Wheels on a '72 C10?
I want to run a set of 5 x 4/3" Camaro Z-28 steel wheels on my '72 C10 with factory 5 x 5" wheel and Power disc/drum brakes. I have read threads where some recommended re-drilling the front discs for the car pattern. Would the same apply for the rear axles (and drums)? I have a concern of weaking the parts by this method. Has anyone done a conversion using GM or aftermarket parts to change out the bolt pattern? Thanks in advance. bg
celcius232 is offline   Reply With Quote
Old 06-19-2011, 04:11 PM   #2
SCOTI
SCOTI's Avatar
Re: 5 x 4 3/4 Wheels on a '72 C10?
Like you mentioned, some front 5x5 pattern rotors can be re-drilled & have the hub snount machined down slightly. Moser Engineering can make correct length axles for your truck rear end that have the car lug & hub dimensions.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-20-2011, 12:28 AM   #3
celcius232
Are there any front discs with the 5 x 4 3/4 pattern that will bolt on a '72 c10 rather than drilling them?
Old 06-20-2011, 12:43 AM   #4
SCOTI
SCOTI's Avatar
Light duty 1" rotor spindles? Yes.
HD 1.25" rotor spindles, no.
Problem is, you'll spend more money swapping over to the 1" spindle than you would just getting the rotors re-drilled (lt duty brakes require different spindles, rotors, & calipers).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
