Old 06-19-2011, 09:18 PM   #1
tabarcus
72ChevyStep
Rear End
1972 Chevy C-10, 12-Bolt, 5-Lug Rear End, $100
tabarcus is offline   Reply With Quote
Old 06-22-2011, 09:33 PM   #2
tabarcus
72ChevyStep
Re: Rear End
ttt
Old 06-23-2011, 12:28 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Rear End
is it a posi?? If so, what gears? would you remove the carrier and ship? if so, how much to 28031?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-23-2011, 01:59 PM   #4
tabarcus
72ChevyStep
Re: Rear End
Not sure. Assume it is a 373. For a fact it is a 12 bolt with 5 lugs. Will ship if you make the arrangements for pickup.
Old 06-23-2011, 03:10 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Rear End
So it sounds like you would rather sell the whole axle housing and not just the internal carrier/ gear?.....
Geoff with a G
Old 06-23-2011, 04:32 PM   #6
tabarcus
72ChevyStep
Re: Rear End
How does one remove the internal carrier?
Value, $100?
Old 06-23-2011, 09:38 PM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Rear End
tabarcus....to remove the carrier, you'll have to pull the diff cover, pull the axles pin from the carrier, pull the axles, then remove the 2 caps on either side of the carrier and work it out.....BUT, I'm only interested in this if it's a POSI, you can tell this by looking for the codes on the ring gear, (which can be done after pulling the diff cover, should be on the outside of the gear...may have to spin the wheels)
OR if ya don't want to pull the cover, just jack up the rear, and spin one of the tires...if the other goes the same direction it's a posi, if it spins in the opposite direction, it's a an open rear
Geoff with a G
Old 06-23-2011, 11:49 PM   #8
weeble
weeble's Avatar
Re: Rear End
Terry, hows it going, seriously interested in the rear end. If I sent you the money could i wait till sometime in July to pick it up?
weeble is offline   Reply With Quote
Old 06-24-2011, 07:59 AM   #9
tabarcus
72ChevyStep
Re: Rear End
Have local interest. So will pass on removing the carrier. Thanks.
Old 06-24-2011, 07:54 PM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Rear End
no problem....if it falls thru and is posi, I'm still interested
Geoff with a G
