Old 06-19-2011, 10:48 PM   #1
Mucknorris
NP 205 paint?
I recently purchased a NP205 that had been sitting outside for some time and have removed the rust from the case as best I could. My question is in regards to what type of paint to use. I would like to coat the inside and outside of the case, but am unsure as to whether or not the oil inside the case will break down the paint. I am planning on using Rust Bullet.
Mucknorris is offline   Reply With Quote
Old 06-19-2011, 11:03 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: NP 205 paint?
1st off welcome to the board... Are you looking for the stock colors???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-20-2011, 12:40 AM   #3
71 super
71 super's Avatar
Re: NP 205 paint?
As pictured above, it should be a chrysler red (closest to what it was originally) . When I cleaned mine it still had the red paint in place.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-20-2011, 05:21 AM   #4
JimKshortstep4x4
Re: NP 205 paint?
I use Chevy Orange engine paint.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-20-2011, 07:39 AM   #5
jamesi20
jamesi20's Avatar
Re: NP 205 paint?
Use Glyptal on the inside.
Multi-Purpose GlyptalŪ Red Enamel seals uneven surfaces in engine castings to improve oil circulation
Glyptal 1201 seals the rough interior castings of engine blocks to help prevent engine damage. Sealing the tiny pores left in metal after bead blasting leaves the engine block interior smooth and clean, and that helps keep oil clean and flowing freely.
Acid- and oil-resistant
Also resists moisture, heat dust, salt spray
Anti-corrosion protection
jamesi20 is offline   Reply With Quote
Old 06-24-2011, 07:13 PM   #6
Mucknorris
Re: NP 205 paint?
Thank you for the input, I will put it to use.
