whats is the best way to put the under the window trim on?
i want to install the trim that runs from drip rail to drip rail under the rear window.. i know the trucks that came with this trim have little nails that stick out with nylon clips that go on them... so how do i put trim on mine even though it doesnt have those pins?
thanks for anyhelp you may give! |
Re: whats is the best way to put the under the window trim on?
I know some used double sided tape but I dont really like that idea and I dont think you would either but it is an option I had the pins your talking about on my cab but I took them off and dont have them anymore but the look just like nail heads so maybe you could try to make your own pins of it comes down to it hope that helps you Ricky
1969 Chevy C10 Short Step -Project 2005 GMC Sierra Crew Cab 1500 -DD 2017 Laguna Orange Roadglide - Good Weather DD |
yes double sided tape isnt my favorite.. how would i put the nail heads back on?
What was I thinking?
You can weld those little nails right back on! Most stud guns (used in the body shop business) for pulling out dents has an attachment for putting those back on. You can buy the trim studs. Most guns come with a bag of them.
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
actually tape is really not the best way. We sell the little tiney screw in studs that attach the plastic clips to attach it. Weld on studs work but is better if unpainted but the screw in studs will keep it on. Its only like $10.00 for all the studs and plastic clips. all you need is a drill bit.
wow cool i would like to do a white top on my 67 and i wnatthe trim if i wil be seperating colors on the body. thanks for the help guys ill see what i can do.
Anyone tell me how to get this off and save the molding?
It should just pop off. You might use a putty knife or a gasket scraper to get it started.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
It's like making your bed in the navy you start from the middle and work your way out try and push the drivers piece straight horizontally to the left and the passenger piece straight horizontally to the right but it should only slide out no more then an inch if if slides more then that and the clips are still attached then it's gonna make you work for it!
