Old 06-20-2011, 09:32 AM   #1
blackbeaSSt
02 burb washer fluid leak?
seriously?!! came out this morning and saw a small puddle on the front drivers side. thinking nothing of it and that it was just rain from last night running off i get in and head to work. sure as the world when i pull out of the driveway the "low washer fluid" light comes on. i get to work and look and yup, leaking washer fluid.
theres no cracks on the bottom and it kinda looks like it running down from the top (which i can't see from the engine bay). any ideas as to where to look?
blackbeaSSt is offline   Reply With Quote
Old 06-20-2011, 11:10 AM   #2
thomas_a_reed
thomas_a_reed's Avatar
Re: 02 burb washer fluid leak?
I had the samething happon in my 01 Silverado.. Mine had a hair line crack in it that was hardly noticable..I found it by taking it off and filling it with water.. Took my drimmal and grooved it a bit and filled it with jb weld.. worked great ever sence.. or you could get lucky like my buddy and all his was the rubber gromet around the pump..
66 CHEVY STEPSIDE 2WD W/283 ( FAMILY HAND ME DOWN)
81 CHEVY SHORT BED 2WD W/250 4SPD TRANS STRAIGHT 6 ( CURRENTLY UNDER CONSTRUCTION)
01 SILVERADO SHORT BED 2WD W/4.3 5SPD TRANS ( DAILY DRIVER) Sold
03 SIERRA 4X4 STEP SIDE EXTRA CAB 5.3 AUTO( NEW DD)
09 CHEVY COBALT W2.2 AUTO (GF'S DAILY DRIVER)
thomas_a_reed is offline   Reply With Quote
Old 06-20-2011, 03:11 PM   #3
blackbeaSSt
i guess the battery has to come out to get the tank out?
Old 06-20-2011, 03:56 PM   #4
thomas_a_reed
If I remember right yes.. I think theres 1 or 2 bolts under that battery and one inside the inner fender.. pretty easy only took me like an hour or so not counting the dry time for the jb weld..
Old 06-20-2011, 03:59 PM   #5
blackbeaSSt
thanks tom. i'll give it a whirl later tonight
Old 06-20-2011, 04:39 PM   #6
truckdude239
truckdude239's Avatar
i just fixed a customers here at work he bought a new tank turns out the washer motor had cracks in it replaced both motors and rubber grommets
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-21-2011, 11:20 AM   #7
blackbeaSSt
well crap i can't even get my damn battery out LOL! how are you supposed to get the side posts off? there isn't a screw or nut or anything.
Old 06-21-2011, 12:07 PM   #8
thomas_a_reed
Should be just to 8mm bolts and a 13mm on the hold down..
Old 06-21-2011, 01:32 PM   #9
blackbeaSSt
i'll take a pic and post it tonight. its almost like the bolt is rounded off. and its uber small. about the size of a pencil eraser
Old 06-21-2011, 07:29 PM   #10
blackbeaSSt
son beach is almost rounded! might be time for the vise grips!
Old 06-22-2011, 07:15 AM   #11
truckdude239
yup time for vise grips and new bolts
David fuller
2000 Tahoe 5.3l 378
Old 06-22-2011, 07:46 AM   #12
thomas_a_reed
Defantly agree with truckdude.. Vise grip and a new battery bolts.. just be carefull not to hit the vise grip on the fender...
Old 06-22-2011, 11:02 PM   #13
BP68
BP68's Avatar
Agree, vise grips or channel locks and new bolts. Leak will maybe be jug, probably pump. Also be sure to check the lines/hoses near the battery for spilts also.
I see this a lot working at a chevy dealer. Usually from a leaky battery.
Pull battery, three 10mm bolts hold tray in, one 10 on the neck of jug, one down low behind the inner fender liner, and a push retainer or two on liner. Line joint by fuse block, then pull up whole assembly to check for multiple leaks.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 06-27-2011, 03:47 PM   #14
blackbeaSSt
yeah i pulled the battery (not the tray...yet) and nothing to be seen from up there. so i filled it up with water and looked underneath again. it looked like a 1/4 of the way up there was something like a black grommet or something that every time i touched it more water was coming out. guess i'll have to yank the tray and fully pull the tank out.
Old 06-27-2011, 04:06 PM   #15
thomas_a_reed
You should be able to take it out from the bottom with out removing the tray. Thats how i did mine.. With out a picture the only grommet i can think of is around the pump.. Common leak point.. A GM Dealer should be able to get you just the grommet..
Old 06-28-2011, 09:52 AM   #16
blackbeaSSt
cool. knowing teh stealership they'll charge me $50 for a grommet
Old 07-22-2011, 11:43 PM   #17
rare86
Extended cab fanatic
rare86's Avatar
This is great info, just wanted to say thanks to all who posted info. I've had 3- 01s and they all leaked. Kinda weird tho, they didn't leak until after changing the battery. Now, I have info on what to look for when I go to fix the two I have. Thanks again
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
