C10 Club Tennessee
Can I run 2500's on the front of a burb?
Just wondering
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
AIRBAGPARTS.COM
Re: Can I run 2500's on the front of a burb?
Can you? Yes....
Should you? No.... With a small bag like that. You are going to need a lot of pressure to lift a large vehicle like you have. You should go with a 2600 or 7" bag in the front. |
C10 Club Tennessee
thanks Jason, that's what I was thinking. I just needed someone to slap me upside the head with it.
really depends on the bracket/ leverage and engine... we did my buds on a slam SS6 and it works just fine which has a 350 with a blower... while at air ride our duramax duallies where sporting firestone 255c bellow or generic term 2500 it all depends man... stock arms with standard brackets id go with a slam ss7, firestone 6873
C10 Club Tennessee
I'll be running an LS motor when I get one.
low n' slo
![]() Join Date: Mar 2009
ive got dominator 2500's in the front of mine
but, the only reason im running them is because my cupped lower a arms were a tight fit with the 2600's. it does take some good pressure to get it up there... just curious, what would be the reason running 2500's instead of 2600's?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
C10 Club Tennessee
No reason in particular, there is a set here locally for sale.
mostly comes down to adequate pressure/ spring rate ratio.... to big of a bag you will achieve your preffered ride height befor the actual bag is at its operational ride hide which will not give you enough rate and to small you will over extend the bag which will give it to much.
way2lo2
![]() Join Date: Sep 2004
an aluminum LS MOTOR AND 2500s WILL BE JUST FINE, my 63 rode @65-75lbs.....I wouldn't hesitate one bit to run them
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote. 216 481-5219 office 216 481-4240 fax 216 789-1647 mobile Way2Lo2@aol.com <----also my paypal http://www.hubgarage.com/mygarage/way2Lo2 |
