Old 06-20-2011, 11:41 AM   #1
Low87
been here longer than Liz
Low87's Avatar
changing wheel bearing
Gotta change the pass side wheel bearing, might as well do the drivers side while I'm at it. A buddy said to change the rotors at the same time so you have a new race. Looking at parts on rockauto, is all I'll need the rotors and the bearings? I've never done this repair before, so advice would be appreciated. This is on the 89 K5.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 06-20-2011, 11:58 AM   #2
ont_guy_38
ont_guy_38's Avatar
Re: changing wheel bearing
I'm not sure if the bearing race comes in new rotors . You should get a new race with the new bearing
ont_guy_38 is offline   Reply With Quote
Old 06-20-2011, 12:16 PM   #3
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
there is an inner bearing and dust seal, outer bearing, washer, castle nut, cotter pin and dust cap, new rotors for the price are worth while and the race is machined into them, I am just installing this setup today myself on my 68 which came with the 73-87 upgraded setup
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-20-2011, 12:16 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
always use a new cotter pins ,is my advise
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-20-2011, 01:23 PM   #5
ont_guy_38
ont_guy_38's Avatar
Ah ok i couldn't quite remember it has been awhile
Old 06-20-2011, 01:44 PM   #6
Rons86
Rons86's Avatar
If the rotors are original I would change them just to be safe. They do come with races, but they are pressed in not machined. If you are not sure of the age have the auto parts store check them. If they are good, get new bearing and races only.
Rons86 is offline   Reply With Quote
Old 06-20-2011, 02:00 PM   #7
sumran
sumran's Avatar
If the rotors are flat and within spec, changing them is a waste of money, IMO. Rotors are a consumable (slowly, if the brakes are properly maintained) part that have a very simple job. The races are inexpensive and are designed to be replaced without replacing the rotors.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 06-20-2011, 02:22 PM   #8
Low87
Low87's Avatar
Ok, he made it sound like if you had to replace the race and not the rotor, it went outside the typical shadetree mechanic capabilities. No idea on the rotors, just thought for the price and knowledge of condition I'd change them anyways.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 06-20-2011, 02:48 PM   #9
tantrumpipeline
my mistake, just had a look at mine and I stand corrected definietly pressed in
20 Duramax tow pig
52 short project
Old 06-20-2011, 02:52 PM   #10
sumran
sumran's Avatar
You can knock out the old races from the opposite side with a screwdriver and hammer. The new ones can be put in with a press but it is not necessary. Use a wood block to protect the edge and tap the new race in until flush. Then place the inverted old race on top of the new race and tap it in until fully seated. The old race will seem stuck at first but can pried out quickly with a screwdriver.
There are other ways to do it but this works well for me. If you decide to replace the rotors you will want to install new brake pads.
Randy Summers
Old 06-20-2011, 03:29 PM   #11
RandyP
Getting Old; Going Broke
RandyP's Avatar
If you're worried about doing it Greg and need to practice on one... I'll buy the parts and you can practice on my 79.
btw, thanks again for the tires! I forgot about the rocker thing, let me know if I need to order that for you.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 06-20-2011, 03:36 PM   #12
Low87
Low87's Avatar
Thanks again guys. I think I'll just replace several things at once to get them updated. Side question - the pass bearing is now squeeling, how bad is it? Can it wait til this weekend or does it need to be done ASAP?
Randy - thanks for getting them out of my driveway! No hurry on the rockers, can't do anything with them for a while anyways.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 06-20-2011, 03:39 PM   #13
tantrumpipeline
bow bad is the noise? have you inspected the brake pads? usually in my experiences the bearing will howl more than squeal, and once it starts it's doesn't take long to grenade, the brakes however find ways to squeal quite often from even road debris
20 Duramax tow pig
52 short project
Old 06-20-2011, 05:33 PM   #14
Low87
Low87's Avatar
Maybe it's a howl, not sure. It's intermittent, mostly at speeds 35 & below. I haven't inspected the brakes. I work 7 days a week this time of year, so I don't really get into anything unless I have to. If I need to change the bearings tomorrow night I will, if not I'll wait til this weekend when I have a little more time.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 06-20-2011, 07:13 PM   #15
texastruckjunky
texastruckjunky's Avatar
I thought a K5 was a 4 wheel drive blazer. So on the outer, there would be no Washer,castle nut,cotter pin, or dust cap. There would be a factory cover or lock out hub, spring, hub nut, washer, and another hub nut.
texastruckjunky is offline   Reply With Quote
Old 06-20-2011, 07:46 PM   #16
LONGHAIR
I would definitely look into this noise. It will be far more costly if you tear something up. If it is just brakes, which is more likely, they can wait a few days.
If the noise really is the wheel bearings....stop now.
A bearing that is making enough noise that you can hear it in the cab is hurting badly. It will get worse quickly. This is doubly important on a 4x4. If the bearings are worn enough the allow the wheel to tilt on the spindle, it can destroy the inner workings of your lock-out hubs.
BTW a brass punch is the best way to drive the races out. There is a cut-out area in the back side of the machined area where is fits just for that. You may need to clean some grease out of the way to see them though.
It's a fairly deep reach to the inner one, from the front side.
You are going to need a spindle-nut socket too and probably some snap ring pliers, depending upon which type of lock-out hubs you have.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-20-2011, 08:15 PM   #17
lilpoindexter
lilpoindexter's Avatar
Don't use a screwdriver, you might scratch or nick the surface the race goes in.
Harbor Freight has a seal installer/ remover tool that does the trick, and it helps you drive the new race in, nice square and easy. My 2wd 1/2 ton '78 had nice rotors, but i wanted to replace the bearings when I lowered it, because the old bearings looked like they had taken on water at some point.
http://www.harborfreight.com/10-piec...set-95853.html
Best $30 bucks you'll ever spend.
lilpoindexter is offline   Reply With Quote
Old 06-21-2011, 01:34 AM   #18
tantrumpipeline
look at me all excited over my own junk I overlooked the main point of the problem, sorry I'm on a 2wd myself
20 Duramax tow pig
52 short project
Old 06-21-2011, 10:35 AM   #19
Low87
Low87's Avatar
No noise at all yesterday evening or this morning.
Yes, it is a 4x4.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 06-21-2011, 10:54 AM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
i had low speed noise come from the front hubs
goes away higher speeds or
the squealers on the pads
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-21-2011, 07:43 PM   #21
texastruckjunky
No worries i've been there my self from time to time.
