Old 06-20-2011, 12:11 PM   #1
KVB
Bed pine
I was wondering if the original type of wood used for the bed is still available? From what I can find is it called Southern yellow pine, but that seems to be a generic all encompassing term.
http://en.wikipedia.org/wiki/Southern_Yellow_Pine
has anybody used this to do thier bed? What did you treat the wood with once it was installed.
Ken
Montreal
1965 C10
KVB is offline   Reply With Quote
Old 06-20-2011, 01:32 PM   #2
jbgroby
jbgroby's Avatar
Re: Bed pine
Thats what MAr-K uses for thier wood. Do some reading on the site all sorts of great infor. Mar-K.com
jbgroby is offline   Reply With Quote
Old 06-20-2011, 01:45 PM   #3
vgnope
vgnope's Avatar
Re: Bed pine
I used some 3/4 plywood as base, then on top I laid down 3/4" x 7" spruce.. All th wood was jus wood I got from wrk..shipping wood..so th cost was low, but the bed looks great.. However make sure the wood your going to use is strong.. I was originally gonna use teak, or marine deck wood..wouldn't have to treat.. But I went the easier route..I can replace any time..
vgnope is offline   Reply With Quote
Old 06-20-2011, 02:53 PM   #4
64fleetside
Re: Bed pine
I've used Mar-K pine in 3 or 4 beds so far, all fit great. Hard yellow wood. Paint is about the only thing that will withstand outdoor weather.
64fleetside is offline   Reply With Quote
Old 06-20-2011, 04:31 PM   #5
62 short step
62 short step's Avatar
Re: Bed pine
Treat the wood with an oil made for hardwood, it will last alot longer than a clear poly or a varnish. It will not peel later like the poly or varnish.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 06-20-2011, 05:01 PM   #6
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: Bed pine
Mar-K did some interesting tests:
http://www.mar-k.com/wood_finish_testing_i.html
I wanted a functional bed so I got yellow pine locally for mine and had a friend mill it, haven't installed it yet.
I wouldn't use oak for a truck bed that'll see weather and I think the mar-k tests show that.
what's available up there, spruce?
Larry
fleetsidelarry is offline   Reply With Quote
Old 06-20-2011, 05:49 PM   #7
KVB
Re: Bed pine
"what's available up there, spruce? "
I can get almost any kind of wood up here through local importers, except for southern yellow pine.
A friend of mine is heading home to North Carolina for a vacation this summer and will try to bring some home for me.
thanks for the input.
Ken
Old 06-20-2011, 06:39 PM   #8
kieth
kieth's Avatar
Re: Bed pine
I bought #2 southern yellow pine boards for $56.00 we used por 15 semigloss black plus 3 coats of semi gloss black enamel from home depot.(uv protection) this is what the original bed looked like but the ss polished hardware is a little upgrade. Kieth
before black
http://kieth.smugmug.com/Trucks/66-G...365_yxLV5-A-LB
after black (1st 3 coats)
http://kieth.smugmug.com/Trucks/66-G...224_ovJCN-A-LB
kieth is offline   Reply With Quote
Old 06-20-2011, 07:19 PM   #9
Chevyman680063
Chevyman680063's Avatar
Re: Bed pine
You should come down to the central GA area. We have plenty of dang pines everywhere. Things are aggravating during the spring with all the pollen and they leave black specks all over your vehicle too if you're parked under one. They're not very strong either. A good gust of wind will take them down.
1963 Chevrolet C10 Short Step
1968 Chevrolet C10 Short Step
Chevyman680063 is offline   Reply With Quote
Old 06-20-2011, 08:09 PM   #10
KVB
Re: Bed pine
Keith,
thanks, that after shot is what I am looking for.
Ken
Old 06-21-2011, 12:45 AM   #11
vgnope
vgnope's Avatar
Re: Bed pine
Yah a good gust of chainsaw and I didn't hear nothin, what tree?
Old 06-21-2011, 02:12 PM   #12
kieth
kieth's Avatar
Re: Bed pine
Originally Posted by KVB View Post
Keith,
Ken
You are welcome, the wood was not expensive $ 56.00 the paint was about $50.00 1 qt por 15 satin 1 qt beahr satin black enamal.....
Look what we did today: http://kieth.smugmug.com/Trucks/66-G...977239_XBJQKNf
Old 06-21-2011, 11:55 PM   #13
blackedoutharley
Re: Bed pine
After reading the Mar-K test results I think painted with stainless strips looks great!
blackedoutharley is offline   Reply With Quote
