Old 06-20-2011, 12:57 PM   #1
A-J
A-J's Avatar
'67 C-30 Frame & Suspension
Hi everyone
I've been reading on the forum for a couple of weeks now and I can't quite seem to find much info for what I'd like to do (if possible). This is my first truck project and the goal is to lower the dually a significant amount WITHOUT bags and retain the bed load capacity. I don't know for certain, but perhaps 8" in the rear & 6" in the front.
Most articles I see deal with airbags when it comes to the frame. What are some of the methods I can use to lower the rear of the frame without bags? I know there's C-Notching, leaf spring flips, and I've seen people "Z" the frame. What's my first step with regards to this decision? Do I determine my exact ride height that I'm looking for? I've attached a picture of the truck.
~ AJ
A-J is offline   Reply With Quote
Old 06-21-2011, 05:10 PM   #2
A-J
A-J's Avatar
Re: '67 C-30 Frame & Suspension
Too vague of a question..?
Old 06-21-2011, 06:50 PM   #3
SCOTI
SCOTI's Avatar
Drop spindles & shorter drop springs up front. Flip the rear on top of the leafs in the rear. This should get you around a 5" front/7" rear drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-22-2011, 12:19 AM   #4
A-J
A-J's Avatar
So we're not talking re-engineering the rear suspension so much as re-locating..?
Old 06-22-2011, 10:09 AM   #5
SCOTI
SCOTI's Avatar
Anything can be done. But the simple flip kit yields x" of drop (x = 1/2 the dia of the axle tube plus the height of the spring pack). It's still going to ride like an old C30 though. To get drop & improve ride quality is where air ride shines....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-22-2011, 10:24 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum A-J. What your asking for is kind of a "have your cake and eat it too" scenarios. Trying to radically lower your truck, improve the ride "and" maintain it load capacity can be a complex request.
As Scoti mentioned, standard lowering techniques will get you down. If you want a better ride you will need to loose some the your load capacity, or add air suspension. Your best solution is a combination of all of those elements.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-22-2011, 01:23 PM   #7
A-J
A-J's Avatar
I can deal with poor ride quality. I've built some imports (Sorry..!!) over the years that almost required a kidney belt for trips longer than 10 minutes. I'd for-go some of the bed capacity if need be. My goal would be throwing a couple of Harley's on the back. Gosh, I'm so new to trucks I don't even know my bed capacity stock. My books haven't show up from UPS yet. LOL
Old 06-22-2011, 01:29 PM   #8
71swb4x4
71swb4x4's Avatar
Flipping the axle may severely diminish your load capacity without an extreme notch. My 67 has a huge spring pack, and if I flip it I am not sure I will get much weight on it before I am hitting the frame.
You will probably need a combination in the back. Maybe pulling some leafs, adding air bags as "helpers" and a notch.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-22-2011, 05:30 PM   #9
A-J
A-J's Avatar
Can someone show me a good example of a flip-kit..?
