Old 06-20-2011, 01:10 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Cant align lokar shifter. Any help?
71 chevy. 454. 2wd. Th400 trans. I have the lokar shifter on the stock column. I have it setup now.. Its hard to tell if your in park. If your backin up in reverse you have to hold the dang thing or it falls into neutral.
I called lokar and he made me feel like an idiot. "just adjust it" lol.
Any tips on getting this thing to function SLIGHTLY ok?
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 06-20-2011, 01:33 PM   #2
John Gilbert
Re: Cant align lokar shifter. Any help?
Call Lokar back and try it again. I've worked with them in the past they're good guys it's hard to imagine they gave you a bad time. I'm not saying it can't happen, always find out the name of the person you're talking to before your conversation starts. No company wants an unhappy customer.
John Gilbert is offline   Reply With Quote
Old 06-20-2011, 01:35 PM   #3
lyrikz
PITbut
lyrikz's Avatar
Will do.
Ya, the conversation was very short.
I explained my vehicle, and what part i had. And said i cant get it to adjust. Any tricks or tips?
He just was quite for a bit and said, just adjust it....
I asked if he had any other techniques. He said nope.
Will call back.
and sold.
Old 06-20-2011, 01:54 PM   #4
John Gilbert
Make sure to get the person's name you're talking to. It will help for any kind of future reference.
Old 06-20-2011, 02:51 PM   #5
cwgreen1971
cwgreen1971
cwgreen1971's Avatar
I put one on my truck and it doesn't stay in park very well, I'm afraid it's going to fall down into neutral one of these times it idling.
cwgreen1971 is offline   Reply With Quote
Old 06-20-2011, 03:01 PM   #6
lyrikz
PITbut
lyrikz's Avatar
YEP!!! THat is my fear 100 percent....
and sold.
Old 06-20-2011, 03:05 PM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
Mine was hard too. had to pick P or L1 to line up and I picked P.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 06-20-2011, 03:49 PM   #8
lyrikz
PITbut
lyrikz's Avatar
I dont mind if my lever doesnt match with what gear im in. I just want it to be in the right gear. If im in park, i want it to stay in park y aknow.. It drops out of reverse. And park is damn sketchy
and sold.
Old 06-20-2011, 03:50 PM   #9
ubtripn
ubtripn's Avatar
I had to bend mine some to fit my 700R4 which they said is a natural part of the install. (If we are talking about the rod leading to the tranny.)
ubtripn is offline   Reply With Quote
Old 06-20-2011, 09:41 PM   #10
gonnuts
gonnuts's Avatar
Ya me too, also to clear my exhaust. It works great now my shifter rattles when driving.
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4
gonnuts is offline   Reply With Quote
Old 06-20-2011, 10:09 PM   #11
Pkh66
I had exact problem with mine until last weekend. Tinker with it. I had to shorten the linkage a tad and move the lever on tranny up a tad. Started to wish I hadn't messed with it until I hopped back in the cab. No more holding for reverse. If it helps set the linkage while both are in R. That's what I did. It was hard to keep the column in R but I set it up there. The indicator is much closer now too. Hope that helps.
Pkh66 is offline   Reply With Quote
Old 06-20-2011, 10:59 PM   #12
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Just adjust it
lyrikz, On yours I would start by disconnecting the shift linkage and put the column and trans in park. When the column is in park the shift lever should fall or spring forward a bit locking it in park. Then with the trans lever at about 8-9 o-clock (Guys with OD may need to go up to 10 o-clock) adjust the rod part of the linkage so its the correct length from the column to the trans lever. You will want to bolt the linkage to the trans lever at about 1"-3/4" from the end, if you don't you will end up with the pointer not lining up with the correct gear on the indicator (as others have seen) or not enough range to your shift lever to get down to 1st. Hope this make sense.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-20-2011, 11:20 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
member hubscrub had/has a cable lokar shifter and he junked it and used a piece of all thread lol
John
1999 Toyota Tacoma 4x4
