Old 04-01-2003, 11:35 PM   #1
conman
Overdrive In A 1982
I was looking at a truck to buy. It is a 1982 1/2 ton with a 305, the trans selector has 1,2,3,n,r,park. with the word overdrive written across the top. What type of transmission would this probably be? The point being I would pull the 305 and replace with a 454. Should I also swap my th400 or use the tranny already in the truck?
Fayette Alabama
conman is offline   Reply With Quote
Old 04-01-2003, 11:56 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Only the 82's and 83's had the selector that has the words Automatic Overdrive. The tranny is a 700R4. Unfortunately the 82-84 trannys were the worst. They only had a 27 spline shaft for the converter. Any stout block will strip the torque converter shaft. That is one reason GM went to a 30 spline shaft on 85 and later 700R4's. Use the 400TH or get a rebuilt 700R4 to last behind the 454.
The gear selector should be R-N-D-3-2-1 right?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-02-2003, 12:12 AM   #3
conman
Your right that is how the gear selector is set up. I believe the 400 would definately be the best bet.
Fayette Alabama
Old 04-02-2003, 02:23 PM   #4
CrazyJesster
CrazyJesster's Avatar
i whould use the 700r4 as a mississippi mudcat trot line wait
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842
CrazyJesster is offline   Reply With Quote
