06-20-2011, 07:07 PM | #1 |
the new guy
I am new to this era trucks, and looking to pick up some info. I recently purchased a 66 k10, I am looking to get power steering for my new rig. I have done some research and I am having a hard time getting info.
06-20-2011, 07:12 PM | #2 |
Re: the new guy
Welcome! I can't help with the 4x4 steering aspect but if you have an inline-6 I can help with the pump/pulleys/brackets. Post up some pics of your rig!
06-20-2011, 07:19 PM | #3 |
Re: the new guy
I will post pics as soon as possible, it is a v-8. thanks for any info!!
06-20-2011, 07:23 PM | #4 |
2lo4me/ntlonuf/ntfstnf
Re: the new guy
welcome to the board, and you should be able to get the power steering adapters and a 4wd steering box from a 70s/80s truck... dont quote me on that though, i havent seen too many 4wd mid 60s trucks.
62 GMC swb fleetside~ project: still undecided 84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME 65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress... 02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable... Last edited by firenuttz; 06-20-2011 at 07:23 PM. |
06-20-2011, 07:36 PM | #5 |
Senior Enthusiast
Re: the new guy
Welcome to the forum! Perhaps one of these threads will be of some help:
http://67-72chevytrucks.com/vboard/s...power+steering http://67-72chevytrucks.com/vboard/s...power+steering Last edited by markeb01; 06-20-2011 at 07:40 PM. |
06-21-2011, 12:32 AM | #6 |
60-66 Nut
Re: the new guy
My power steering adapter plate will work on the 4x4's also. I have sold several to guys that used them on 4x4's. As for the pump and brackets, that will depend on whether you have a small block or big block, short water pump or long water pump. If you can post up a pic of your engine, and we can help you get it figured out.
06-25-2011, 08:48 PM | #7 |
Re: the new guy
The engine is a small block, as for the water pump I have no idea I will try to post pics soon. Thanks for all the info.
06-28-2011, 11:06 AM | #8 |
Re: the new guy
I got my new master cylinder with dual reservoir and vacuum assist. I am going to stay with the drum brakes. Just a little update then on to the power steering.
06-28-2011, 11:31 AM | #9 |
Re: the new guy
I finally got some pics going. The 66 isn't in to bad shape.thanks again for the info!!!
06-28-2011, 12:01 PM | #10 |
Re: the new guy
Pretty darn nice lookin' truck.
I sure understand why you're thinking 'bout p-steering. As far as my personal situation, I drive mine daily and, as good as the manual set-up worked.....I sure am glad I did it. One finger steering......easy in the tight spots. I went with a Hydro-Boost on mine. As I'm running the original GMC V-6, the pump brackets were an issue for me......a few extra hours fab-work. Certainly worth it. I'm thinkin' firenuttz is correct....the '70's stuff will work on your truck. The only possible hang-up might be the frame & steering box issue.... (in which case, CaptainFab's got the right stuff) Again,.....nice K-10
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
06-28-2011, 12:12 PM | #11 |
Custom Builder
Re: the new guy
Welcome to the site! I also have a 1966 K15 with 283 and SM420 4 speed. I used the steering box, lines and pump off a 1972 Blazer K5. The brackets look like you will need ones from a 1973+ because it appears you have the long water pump and balancer from the picture. I made spacers for the frame to steering box but you can use the adapter stated above from CaptFab.
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
06-28-2011, 06:35 PM | #12 |
Re: the new guy
What are the exact years, and parts that I can use for the power steering, given the fact I have the long style water pump?
07-09-2011, 06:26 PM | #13 |
Re: the new guy
Thanks for the info guys its a big help I am new to this whole thing!
07-09-2011, 07:41 PM | #14 |
Who Me?
Re: the new guy
Nice truck and welcome to the gang!!
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
07-09-2011, 08:07 PM | #15 |
Re: the new guy
Very nice truck indeed. I like seeing the 4x4's. Welcome aboard!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
07-10-2011, 01:48 AM | #16 |
Just here to tinker
Re: the new guy
Welcome! I can see why you want power steering. I can't imagine all the fun you have in parking lots! Great looking truck!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
07-10-2011, 03:57 AM | #17 |
Re: the new guy
Thanks guys glad you like the truck. Yea parking lots are a nightmare!!
07-10-2011, 01:56 PM | #18 |
C10 CLUB Y QUE!
Re: the new guy
nice truck!
07-18-2011, 11:12 AM | #19 |
Re: the new guy
I got a few rust bubbles in a few spots any good body guys out there? Wondering how I should tackle the problem before it starts to get worse.
08-29-2011, 06:13 PM | #20 |
Re: the new guy
I am noticing more and more how few 4x4 there really are!! Any idea how many they made from 60-66?
