04-01-2003, 11:55 PM | #1 |
Red
Late model Steering Wheel Fit?
Will most later model Chev. truck steering wheels fit my '72? Was wondering about '89-93ish model trucks?
Any adaptors needed etc.... Planning on junk yard jumpin' this weekend. Mike
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
04-02-2003, 12:37 AM | #2 |
its all about the +6 inches
It'll bolt right on. Look real close at the horn slip ring. You'll need to use your original onw. Just use some pliers to pull the metal contact out of the tube, and then use the spring loaded contact, but first, you'll need to shave the nipple off so it'll go in. It is a tight enough fit that it'll hold no problem.
I've run one in all 3 of my trucks with no problem what so ever. |
04-02-2003, 08:43 AM | #3 |
Red
THANKS!
Mike
04-02-2003, 10:30 AM | #4 |
ALL AMERICAN MADE G.M. CARS & TRUCKS HAVE THE SAME SIZE SPLINE ON THERE STEERING WHEELS. AT LEAST ALL OF THE ONES I'VE TRIED FROM 1960 ON UP, (OLDS,PONTIAC,BUICK,GMC CHEVY, ECT. ECT.) JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
04-02-2003, 11:02 AM | #5 |
Thats the Hillbilly way
this one
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
04-02-2003, 05:39 PM | #6 |
Red
THANKS,
Bill72BB, that is exactly the type of wheel I was thinking about. Mike
04-02-2003, 06:09 PM | #7 |
Cadillac power
Bill-
Got any more pictures of that cup holder setup? I'd be interested in getting any details you have. Thanks!
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style. --Scott Adams author of Dilbert |
04-02-2003, 06:21 PM | #8 |
I've got a wheel like bills and like it.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
04-02-2003, 06:32 PM | #9 | |
http://www.metropartsmarket.com/cata...ole_15039.html
04-02-2003, 06:34 PM | #10 | |
I think the plate for the later wheel would make the horn hookup easier.
04-03-2003, 12:43 AM | #11 |
Teh problem with the plate from the new wheel is the bottom is not the same. On the new ones it is flat while our trucks had a tapered edge that presses against the bearings. I made that mistake once already.
04-03-2003, 01:32 AM | #12 |
Andy ; Should I stop looking for the later model plate ? and stick with the original and the adapted horn wire?
04-03-2003, 03:57 AM | #13 |
I have a later model Chevelle SS wheel in my truck but left the horn fuse out. Ive done this on other trucks with no problem but for some reason, I cant keep the horn quiet this time. My shrink tells me that I need to scream more often. I guess Ill just roll the window down and go for it. I like this steering wheel too much to give it up for a horn. When all else fails, the middle finger works well too!
04-03-2003, 11:08 AM | #14 | |
04-04-2003, 01:56 AM | #15 |
Here is the bottom shot of the two styles in question... The one that has a tapered end is for the truck, the other one is an early 90's S-10 which donated a 4 spoke padded wheel.
04-04-2003, 01:59 AM | #16 |
This angle shows the height a little better. The black one is out of a mid 70's van (a tilt deal) and I only threw it in the pic to referance the metal contact.
I normally just grasp the metal with pliers and pull. They normally come out with no problem and I have even been able to save one or two. |
04-04-2003, 11:13 AM | #17 |
i have an 87 wheel in my truck and i like it alot i havent messed with the horn yet and probably wont untili have to go get inspected.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
04-04-2003, 01:34 PM | #18 |
Bill72BB, I never answered your Q...sorry.
Stop looking for the newer style. When you install it your upper bearing will ot have the support they need and everything will be real sloppy. So sloppy in fact, that the bearings will pop out of the race, and the turn signals will not cancel. |
04-05-2003, 03:49 AM | #19 |
Thank's Andy so far the adapter wire I made is holding up pretty good still have a horn that works .
04-05-2003, 09:25 AM | #20 |
dont know if anyone cares but I used a 90's S-10 wheel with the original plate, horn, turn signals work properly and the stearing is fine.
04-05-2003, 10:48 AM | #21 |
I used a full size truck whell out of a 93 chevy extended cab, and all I had to do to get the horn to work was take the horn wire and cut th end off and put a female connector on it and plug it on the inside of the horn button on the new wheel. You remove the horn cap and you will see the male connector inside of it. All this does is ground the wire and therefore makes the horn work.
