Old 06-21-2011, 01:15 AM   #1
WB72
Before and After
WB72's Avatar
You can't see me stopping
My Brake lights just quit working.
Is there an easy, one man way to determine the part that is defective?
Brake switch
Proportioning Valve
Are these are the only things that I will have to check? What is the proceedure of checking them? Test light? Is it just that easy?
If the proportioning valve is defective, will I get any power to the brake switch?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 06-21-2011, 01:38 AM   #2
Autoblueprint
Autoblueprint's Avatar
Post Re: You can't see me stopping
Always check the fuse(s) first. If ok, then test for power in / out at brake light switch with test light ( check switch fore / aft adjustment too ). If switch powers ok, and adjustment ok, then problem is somewhere in harness from switch to bulb. Check bulbs first.
Problem most likely is a bad fuse or brake light switch.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 06-21-2011, 05:13 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Prop valve has nothing to do with your brake lights.
The stop light switch that activates the brakes is under the dash on the pedal cluster.
Old 06-21-2011, 07:13 AM   #4
eagleuh1
eagleuh1's Avatar
Check fuse, check bulbs, check ground wires at back,Check harness at back is plugged in , no cuts in wires, check break pedal switch connector is plugged in good. Check that the pedal pushes on the little pin in the switch to turn on the lights.
eagleuh1 is offline   Reply With Quote
Old 06-21-2011, 08:48 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
check the parking lights, if they work, the fuse is fine
check turn signals, if they work, the bulbs are fine, as are the wires going the length of the truck.
check the switch. 2 wires, orange and white. Full time power on one wire, power on the other when the pedal is depressed
Everything tests ok so far, then you will 99% chance need a turn signal switch.
To check this, have an assistand looking at the tail lights, or you can back up to a wall/garage door at night and watch them in the mirrors. Engine on or off, key on or off, it doesn't matter. Hold the brake pedal down, notice if the brake lights are out. LIGHTLY wiggle the turn signal lever up, and then down, forward and back. If the brake lights come on at any point, then go get a turn signal switch.
Old 06-21-2011, 10:16 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
Nice easy info there LHM!!! Thanks
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-21-2011, 10:23 AM   #7
WB72
Before and After
WB72's Avatar
All great info, I will get working on it.
To confirm, the brake lights are the only thing that doesnt work, the signals do work, could there still be an issue with the turn signal switch?
66,000 miles.
Alberta, CANADA
Old 06-21-2011, 11:52 AM   #8
coop34
I just recently had a similar problem and replaced my turn signal switch just last night and the problem is gone. Check everything that longhorn suggestion and if they all checkout, get yourself a new turn signal switch.
coop34 is offline   Reply With Quote
Old 06-21-2011, 02:30 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Since your brake lights are the only thing not working, it would seem that the grounding for those bulbs is good.
But, for anyone who may have a problem with bulbs not working correctly, or all, just add checking your ground wire connections to LonghornMans' post.
Electricity is like water, it will seek the path of least resistance. If a path for a circuit can be made through another circuit, you'll have dim bulbs when it should be bright...or off, or it will work when it shouldn't....like the right side working when it should be the left...or both working when it should only be one working.
Member Nr. 2770
Old 06-21-2011, 03:07 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Great info as usual from LHM...and I also agree with ChevLoRay on grounding. My bulb cups were loose in the rear of my 70. When the brake lights didn't work, I went back and went to loosen the lense and when I touched the screw the light came on. I turned off the lights, undid it all, cleaned connections, and reattached (tightly) and everything worked fine.
Also, there are ground straps between the body and frame and engine and frame and many times they can cause electrical issues that are hard to diagnose....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-21-2011, 04:50 PM   #11
406 Q-ship
406 Q-ship's Avatar
Yes it still can be the turn signal switch. If you have power going in and out of the stop light switch on the pedal, the wire from the stop lamp switch to the steering column is not broken, and the turn signals work .....then you have a bad turn signal switch.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 06-21-2011, 04:52 PM   #12
bosco200
bosco200's Avatar
Its finally happen....someone ran out of brake light fluid.
bosco200 is offline   Reply With Quote
Old 06-21-2011, 04:55 PM   #13
eagleuh1
eagleuh1's Avatar
Good info to know LongHorn Man. Hey, did you see the nice longhorn in my Petit Jean post. Sorry for the thread hijack WB72
Old 06-21-2011, 04:57 PM   #14
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
good knowledge tx
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-22-2011, 08:30 AM   #15
WB72
Before and After
WB72's Avatar
Thanks all. Gonna get a new switch. That should clear up the issue.
66,000 miles.
Alberta, CANADA
